Date Codes Variance - Block, Intake, and Exhaust
This is probably a question for the NCRS forum, but I figured I'll try my luck here too.
How far apart can the date codes be for the block, intake, and exhaust manifolds? How far apart were they from the factory? I'm missing the intake and exhaust manifolds for my 71 454 and will need to start tracking down replacements soon.
The original block is dated D 8 71, Apr. 8, 71. I would like to keep the date codes as authentic and original as possible.
TIA
TIA
Received 1,468 Likes
Cruise-In II Veteran
The NCRS will accept anything within six months. Usually, casting and assembly dates were much closer.
Mid to late March casting dates would work for you. Possibly even early April. What is the engine assembly date and your time/build code?
Received 2,878 Likes
Hi Duff,
Mike's right about the NCRS using the 6 month time period.
My base engine sb was built the first week of January, 1971; and has an intake manifold with an August 1970 date and proper 1971 casting number on it. Pretty long time?!
It worked the other way too. My trim tag indicates January 14 as the day the car passed the station where the tag was installed. Here's a date from one of the door panels... January 12, 1971. Pretty close?!
Regards,
Alan
Regards,
Alan
TIA
TIA
This is interesting. does this 6 month period also apply to other parts such as mirrors. My 77 has production date of 5-77, my door mirrors are dated 6-DMI-6. now will these mirrors pass as correct for judging?
Hi 77,
I believe the 6 month lead time applies to mirrors too in NCRS Flight Judging.
The other glass... windshields, etc. can have up to a 12 month lead.
Your mirror date sounds a bit early.
Regards,
Alan
Regards,
Alan
Although it would be hard to understand why both mirrors in this case are almost 12 month out of date. Possibly things are different on later C3s?
And I wouldn't worry about it either because the only deduct, if any is for the date which is a 20% deduction on originality...if at all. An exterior judge would probably make a note unless all date codes are out of square.
Engine assembly date is Apr. 23. Car build date is Apr. 29. Thanks for the info.
If you or anyone else is interested I have a correct set of 3969869/3880828 (NO AIR) exhaust manifolds available for a 70-71 454, dates are F2770 & E2770, considering the dates are on the back side where no one will ever see them these might work. send a PM if you or anyone else is interested.
