Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-01-2012, 01:36 PM   #1
C2C6Z06
CF Senior Member
St. Jude Donor '08-'09-'11-'12
C2C6Z06's Avatar
Default At Home Phosphate Coating?
I am at the point of sending off the major frame and suspension parts to the powder coater on my 73 restore/rebuild and need to get the numerous nuts, bolts and washers black phosphate coated. I have found a few shops in the So Cal area that can and will do the parts, but I would like to know if the phosphate coating can be done at home. Is home coating near the same quality as a commercial operation?
It would make my life more simple if I dont have to sort out a 5 gal bucket of parts, and do them a few at a time instead on my timetable.
Where would I find the materials? I have heard of folks using crock pots etc...
Thanks for the help.
C2C6Z06 is offline   Reply With Quote
Old 02-01-2012, 01:56 PM   #2
birdsmith
CF Senior Member
birdsmith's Avatar
I'm at work so I don't have a copy of my latest Eastwood catalog (it's probably listed online though)...I recall seeing a "black oxide " coating kit that they sold awhile back. Check them out- since I'm just down the road in temecula I might send you a bucket of my own bolts!!
birdsmith is offline   Reply With Quote
Old 02-01-2012, 02:39 PM   #3
Alan 71
CF Senior Member
Alan 71's Avatar
Hi C....
Phosphating is really the easiest plating to do at home
The process is called 'Parkerizing' and apparently people who make firearms use it.
The supplies and instructions are readily available. Google... 'Parkerizing'.
I use both the manganese phosphate, (VERY dark gray, almost black), and zinc phosphate, (medium gray).
Here's a m & f hood latch with the zinc phosphate finish.
Regards,
Alan
Click the image to open in full size.
Alan 71 is online now   Reply With Quote
Old 02-01-2012, 03:44 PM   #4
C2C6Z06
CF Senior Member
C2C6Z06's Avatar
Parkerizing? Well I would never have guessed that was the same thing!!!
Thanks Alan...Will look into that angle...BTW, is the hood latch spring the Zinc and the mount Manganese?
And Birdsmith, you can bring a 1/4 barrel of a fine microbrew for the kegerator up with your bolts !
Old 02-01-2012, 06:38 PM   #5
Alan 71
CF Senior Member
Alan 71's Avatar
Hi C2,
The latches are the zinc phosphate.
This isn't a great picture but the 4 bolts for the rear spring, the bolts for the top mounts of the shock absorbers, the drive shaft universal joint bolts, and some washers and nuts, are manganese phosphate. You can see they're almost as black as the painted spring mounting plate.
Regards,
Alan
Old 02-01-2012, 07:06 PM   #6
Mooser
CF Senior Member
Support Corvetteforum!
Mooser's Avatar
Quote:
Originally Posted by Alan 71 View Post
Hi C....
Regards,
Alan
Of the different plating/coating, one of the easiest to do at home.
(don't use you kitchen oven)
Also don't confuse it with black oxide, gun bluing or tool-black. Basically if there's no heat, it's not going to do a real good job.
The other thing to watch is for higher hardness steels, there is a possibility of hydrogen embrittlement, although there is some conflicting information out there, most if not all aerospace spec's for manganese coatings call for a 375/4 hydrogen bake afterwards...
From what I remember that kicked in at around 30Rc
Mooser
Mooser is offline   Reply With Quote
Old 02-01-2012, 07:12 PM   #7
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
http://www.facebook.com/home.php?
Send a message via AIM to Nowhere Man
Allan where did you buy your stuff to do your work
Nowhere Man is offline   Reply With Quote
Old 02-01-2012, 07:19 PM   #8
Vicky Vette
CF Member
Vicky Vette's Avatar
Alan, I never get tired of your engine bay pictures. Your attention to detail is outstanding!
Vicky Vette is offline   Reply With Quote
Old 02-01-2012, 07:46 PM   #9
bulldog90
CF Senior Member
Default Incredible
Alan that is amazing work
bulldog90 is offline   Reply With Quote
Old 02-01-2012, 10:00 PM   #10
markids77
CF Senior Member
For fiddly small parts and hardware I like either Caswell Plating's Black Oxide finish or another gun related sprayable finish called DuraCoat from Lauer Custom Weaponry. Black Oxide is easy to use, contains no caustic chemicals, and requires no heat to apply... simply degrease, blast, dip and rinse. It is not as hard or durable as real phosphating but is much safer and simpler. DuraCoat is a two part sprayable coating available in any color you can imagine, and is both harder and more durable than cold oxides... it approaches the scuff resistance of real phosphated parts and offers the bonus of being "touch up" friendly if you have an issue with assembly. It does require a spray application, but is sprayable through airbrushes, "touch up" sprayguns or even Preval type self contained aerosol applicators. I use it often and think it's excellent bang for both the buck and effort expended to achieve a good looking and reasonably durable finish.
markids77 is offline   Reply With Quote
Old 02-01-2012, 10:07 PM   #11
Indiancreek
CF Senior Member
I do gun parts with it. You can find your supplies on some gun sales places. I think I got some from Brownell's Or maybe Midway USA. There are some cheaper sources. Stainless bowl will work for small stuff. I use an old behind bar bottle holder for rifle barrels.
Indiancreek is offline   Reply With Quote
Old 02-01-2012, 10:26 PM   #12
markids77
CF Senior Member
Here's a Manganese Phosphate "how to" primmer... Degrease the part to be finished in either a suitable water based hot tank or use a degreaser like brake claner or acetone to clean thoroughly. Blast the entire surface clean using media which cuts fairly aggressively to expose max surface area for finishing. Set up three heaters and either stainless or Pyrex glass containers... one to contain boiling distilled water to preheat and final rinse your parts, one to contain the phosphating solution which must be maintained at somewhere near 190 degrees farenheit depending on who made the salts, and a third container which will contain a passivating solution of some sort. Preheat the clean part in boiling water until heated uniformly, then hang it in the phospating solution until it stops fizzing... 10 to 30 minutes. Transfer to the passivating bath for whatever time the destructions say you need, then back to the clean boiling water to rinse. Blow dry... then oil immediately to prevent "flash rust". Hope you performed all the steps correctly so your parts don't come out mottled or have a "salt bloom"... a white deposit formed from incomplete passivation. Whew! Now you know why I like "dip it and oil it", or sprayable finishes.
Old 02-01-2012, 10:50 PM   #13
gbvette62
CF Senior Member
gbvette62's Avatar
I've cheated on creating a black phosphate finish, by using paint.
By spraying parts with flat black paint, and then giving them a very light dusting with silver paint, I've been able get a fair representation of black phosphate. I dust with the silver from about a foot above the part, and do it while the black is still damp.
With a little experimentation, you can get a credible looking finish on many parts. Don't laugh, I've fooled a few people (including judges), by doing this.
gbvette62 is offline   Reply With Quote
Old 02-02-2012, 04:27 AM   #14
hunt4cleanair
CF Senior Member
hunt4cleanair's Avatar
I've worked with both black oxide (via Eastwood) and the manganese phosphate and have gotten nice results with either. The challenge with manganese phosphate for me has been maintaining the temperature for the heat required with the phosphate plating.
Quote:
These are the steps I've used but curious what others have used to maintain the 190 degrees? I used a cheap crock pot but took forever to get to 190 and than sustain even tho I preboiled the water before putting into the crock and cooking metal before dipping into the plating solution.
__________________
Tom Russo,
Corvette Buildsheet Book: Study Guide for 1973-82 Build Records
The dream lives...enjoy the ride!
hunt4cleanair is offline   Reply With Quote
Old 02-02-2012, 11:21 AM   #15
Alan 71
CF Senior Member
Alan 71's Avatar
Hi,
I'll only add that I've used 'PreLube 6', which comes in a spray can, to protect the parts after parkerizing.
I buy it from Quanta the gas tank people. It protects the finish of natural parts too, and doesn't get sticky or attract dust.
Regards,
Alan
Old 02-02-2012, 11:27 AM   #16
Alan 71
CF Senior Member
Alan 71's Avatar
Hi Keith,
Good to talk to you!
I bought my supplies from Palmetto Enterprises.
Google 'phosphate Palmetto Enterprises'; you see info and phone #.
Can you believe THIS WINTER!?!?
Regards,
Alan
Old 02-02-2012, 11:50 AM   #17
wan2run
CF Senior Member
wan2run's Avatar
I have 2 unopened quarts (1 charcoal, 1 medium gray) of the Palmetto Enterprises phoshating concentrate that I don't plan on using if someone wants to buy them.
wan2run is offline   Reply With Quote
Old 02-02-2012, 02:44 PM   #18
C2C6Z06
CF Senior Member
C2C6Z06's Avatar
Quote:
PM your price (inc shipping to 91786) please...
Old 02-02-2012, 06:41 PM   #19
wan2run
CF Senior Member
wan2run's Avatar
PM sent.
Reload this Page At Home Phosphate Coating?
Tags
1967, coating, corvette, finish, home, hood, instruction, latch, paint, palmetto, phosphate, plate, plating, rifle, zinc
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
