Original Radio Removal
Okay, I pulled the instrument clusted tonight for a repaint. (I'm still looking for a paint I can buy locally that will do the job SEM trim Black 39143 or 5 ball will do and still open to alternative suggestions)
I got the bezel clear but, I'll be doggone, I can't figure how to detach the radio. Feel a bit like a fool, too. I've done far more complicated things, but can separate the bezel from the radio, not wanting to destroy the radio in the process, I thought I'd ask you for some direction. Suggestions?... Strike that... Answers? Ugghhh.
Did you remove the 9/16 nuts from the radio shafts? They are behind the *****. ***** just pull off. Nuts are hard to get to with a socket. Sometimes I use a pair of needle nose pliers. mike...
Received 1,468 Likes
Cruise-In II Veteran
