Cleaning White Convertible top
Old 12-03-2011, 11:54 PM
driddick
driddick's Avatar
Default Cleaning White Convertible top
What is best to clean a white convertible top... just want to get that bright new look again.. its not bad but needs a little cleaning..
Old 12-04-2011, 02:26 AM
Ironcross
Ironcross's Avatar
Ajax or Comet, but don't leave it unattended ....was off quickly after scrubbing...I use to use it on the bottom or rear from exhaust splatter on my white 61
Old 12-04-2011, 05:50 AM
GREGG-73
GREGG-73's Avatar
As stated above..."don't leave it unattended". I would add to the list Bleche-Wite and a good stiff brush. Be sure to keep all painted surfaces wet at all times and rinsed often. And what ever you do....do not use / or complete this job in bright / hot sunlight. Its better to do this on a cooler / overcast day or in the shade, just to ensure the painted surfaces do not get too hot. Try it , you will be amazed at the difference.
Stay in tune.....
Old 12-04-2011, 08:31 AM
BKarol
BKarol's Avatar
Raggtopp seems to get mentioned a lot in the detailing forums:
http://forums.corvetteforum.com/car-...looks-too.html
http://autogeek.commerce-search.net/...topp&x=50&y=13
You can do a search for reviews.
Killrwheels@Autogeek (07-19-2016)
Old 12-04-2011, 09:22 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Soap and water. I use dish detergent or Simple Green - nothing abrasive.
If memory serves, there's a care tag sewn into it.
Old 12-04-2011, 09:26 AM
Lupigiato
Lupigiato's Avatar
Raggtopp is environmentally safe, spray on application, scrub lightly with a brush and let stand before rinse. Raggtopp is safe for paint, though I'm not sure if the same can be said of Comet - not to mention the gritty, abrasive powder that is difficult to rinse 100%.
Old 12-04-2011, 10:55 AM
Ray Y
Ray Y's Avatar
My car had a white Vinyl top when I got it and it was really dirty. I used Simple Green the first time and RaggTopp products after that.
Old 12-04-2011, 11:18 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
If the top material is vinyl (rather than canvas/fabric), you should give it a good coating of Nu-Vinyl or Mequiar's polymer protectant for plastics, once you've got it clean and dry. That coating will keep loose dirt from imbedding in the surface, prevent UV damage, and make it clean up without scrubbing in the future. Just re-coat it about once a month after washing the car.
Old 06-02-2012, 04:30 PM
glc 1971
7th Gear
glc 1971's Avatar
Default Cleaning convertible top
Used simple green on tan top and so far has not faded
color. Waiting on raggtop to come in monday.
Old 06-02-2012, 10:22 PM
markids77
markids77's Avatar
Mr. Clean Magic Eraser. No toxic anything, and available wherever groceries are sold.
Old 06-03-2012, 05:07 AM
Legacy Stables
Legacy Stables's Avatar
yes yes and yes
Old 06-03-2012, 09:14 AM
69 Chevy
69 Chevy's Avatar
Original material for '68-'75 convertible tops is Pinpoint Vinyl.
My Electron brand white replacement top recommends RaggTop products for use and care.
Old 07-18-2016, 12:34 PM
Boatguy95
Boatguy95's Avatar
In a pinch, Simple Green works amazingly well. For routine care and detailing, go with RaggTop.
Old 07-19-2016, 07:06 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
Raggtop and 303 both offer a two step package made for either a vinyl or fabric convertible roof. They both are designed not only to work well, but ok for the environment also. The first part is a cleaner, and the second part is a protectant. Easy to use, and great results.
http://www.autogeek.net/contopcleanp.html
To Cleaning White Convertible top
Quick Reply: Cleaning White Convertible top
