fuse box
fuse box
hi? i have a 82 corvette and i need a fuse panel fuse indicator diagram or fuse lable and fuse number and what it controls. diagram and picture will be great.
thanks
thanks
Received 1,470 Likes
Cruise-In II Veteran
The 82 owner's manual probably shows a picture of the fuse panel and will list the correct fuses. The AIM page is a bit busy.
The diagram you are looking for is in every manual you can buy for an '82 Corvette. Those manuals all have copyrights. There are more than a hundred currently for sale on eBay. There are some in CD form too.
There are several manuals to choose from. The GM shop manual is most comprehensive, the assembly instruction manual (AIM) has the most and biggest pictures (but no text instructions), owners manuals are the cheapest but don't say much about repairs, and the Haynes and Chilton repair manuals are somewhere between the shop manual and the owners manual. Personally, I like the shop manual best, but I own all of the above.
If you are going to do any work on your '82, you should own at least one of these manuals.
