Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2011, 07:35 PM   #1
motornewbie
Junior Member
Default 69 327 Help please!
Hey everyone, just picked up a motor today - needing some help, even though information I have is limited. The guy I got this motor from does not have any paperwork but says this motor pushed around 400 horse. I am looking for hp in that range and decent low end torque.
Ok here is what I got. SBC with block casting # 3979910. My research shows it is more than likely a 350 block, although the guy I got it from swears it is a 327 out of a 69 vette or 69 camaro. Heads are definitely camelback (stamping on front) with casting # 3899462. I took valve cover off and no roller rockers. Has a high rise Weiand X-CELerator intake (#7546).
So I'm going to put on accessories and let it buck. Going to put a high torque mini-starter on. My question comes to other accessories, and will this motor push that much hp?
Thinking about a MSD pro billet distributor - worth it? Would it be a good add on? In addition, I have an edelbrock 600 cfm carb I need to rebuild (manual choke 1405). Would this carb/dist. combo be a good match with this motor? This is NOT for a street application - will have an aluminum radiator, and a 8 3/4 mopar rearend with around low 4 gears - will be run in dirt. Thanks again, I appreciate any help in advance! Thanks!
motornewbie is offline   Reply With Quote
Old 11-20-2011, 08:14 PM   #2
tomgallucci57
CF Senior Member
69 vettes didnt have a 327
tomgallucci57 is offline   Reply With Quote
Old 11-20-2011, 08:22 PM   #3
motornewbie
Junior Member
Ok - so must be out of a 69 camaro then. Thanks.
Any motor guys have any input on the combination I am thinking and whether or not I will achieve the power I am looking for (I know it is hard without cam specs, etc. but I don't have them either).
Thanks again!
Old 11-20-2011, 09:26 PM   #4
gbvette62
CF Senior Member
gbvette62's Avatar
Are you sure about that casting number? I'm not aware of 3979910 being used as a Chevy small block casting number.
Sometimes it can be hard to make out casting numbers, especially after years of paint and dirt accumulates on the block. Is it possible that the 2 middle digits are "00", not "99", making the casting number 3970010. The 010 block is a very common block, that was used between 68 and 79. The 010 was used as a 327 in 68 only. From 69 to 79, it was used as a 350. I think the 69 327 block was casting number 3956618.
Check the dating, on the back of the block. Also, what's stamped on the pad on the right from of the block, just in front of the head? This might help identify what engine you have.
gbvette62 is offline   Reply With Quote
Old 11-20-2011, 09:32 PM   #5
motornewbie
Junior Member
Sorry - laptop keyboard, haha. 3970010 is the block casting. I suppose it is possible it is a '68 block then?
All it says above that casting on the back of the block is a big 19 followed by GM.
On the front of the block, right by the head is a smaller stamped number where 3 digits are wore just about completely - followed by this: VO52OFB. I am guessing on the stamp right in front of this as 196219897. This is all stamped on the passenger side front of the block, just below the double hump mark on the front of the camel back head.
Thank you!
Old 11-20-2011, 09:39 PM   #6
kdf1986
CF Senior Member
kdf1986's Avatar
Hello
It is true the motor could have come out of a 69 vette. But that doesnt make it a 69 vette motor! Think about this. The original vette motor was blown and replaced with an unknown motor. Then the vette gets wrecked. And this person takes the motor out of the 69 vette. So technically he can say the motor came out of a 69 vette.
It doesnt make it a 69 vette motor though.
kdf
kdf1986 is offline   Reply With Quote
Old 11-20-2011, 10:03 PM   #7
motornewbie
Junior Member
Thanks kdf - I understand that, I guess I am less concerned whether or not the motor actually came from a vette - was told it was, so I came here.
It would be more beneficial if I knew it was a 327, and whether or not I can achieve the HP I desire with the above combination - even with limited or no knowledge of any paperwork on the cam, head work, etc. Is it possible?
I thought this number casting block with camel back heads weren't too common and might be a give away towards one common year/option in a certain make - but again check my screen name
Thanks again!
Old 11-20-2011, 10:19 PM   #8
DZRick
CF Senior Member
DZRick's Avatar
I'll have to double check but the block I have in my garage I'm almost positive has a FB stamp.
It was a 210hp 327 from a '69 Camaro with a 2 barrel carb.
I'll check it again and get the casting number too.
DZRick is offline   Reply With Quote
Old 11-21-2011, 08:44 AM   #9
gbvette62
CF Senior Member
gbvette62's Avatar
The casting date is in the same same area as the casting number, but on the right rear of the block. Look for it to the top right of the top bellhousing bolt boss.
Thank you!
From my Chevrolet parts book, V0520FB is a Flint engine ("V" = Flint), assembled May 20th (05 + May, 20 is the 20th day of the month), and "FB" indicates a 327/235hp, 2bbl, Powerglide in a full size 69 Chevrolet.
196219897 is the VIN number of the car that the engine came out of. "1" is Chevrolet, and "9" is 1969. "6" should be the car assembly plant, but letters, not numbers, were used to identify assembly plants. Could it be a "G", instead of a "6", as this would be Framingham, MA? 219897 is the VIN sequence for the car the engine came out of.
The thing that throws me is the 010 block. Everything I have indicates that the 010 block was only used for 350's in 69, and that all 69 327's (as well as some 68 327's), used the 618 block??????
From what I have, the stamping seems to indicate that your engine started life as a 69 327/235hp, 2bbl, with a Powerglide behind it.
Old 12-02-2012, 01:06 AM   #10
motornewbie
Junior Member
Thanks guys - just tearing into this thing now.
So - how do I ascertain if this motor was originally from a corvette? If it was - I have to have a tach drive distributor, correct?
If it came from a Camaro, I can use any distributor I want - correct?
Don't want to drop $$ on a distributor and come to find out it won't work....
Thank you!!
Old 12-02-2012, 10:24 AM   #11
Alan 71
CF Senior Member
Alan 71's Avatar
Hi mn,
The difference in a tach drive distributor or non tach drive distributor won't limit what engine it can be used in, it will only determine whether it will drive a mechanical tachometer or not.
Regards,
Alan
Alan 71 is offline   Reply With Quote
Old 12-02-2012, 03:46 PM   #12
spot99
CF Senior Member
spot99's Avatar
This might help. Copy and paste if the link behaves like your '69.
http://rowleycorvette.com/stats69.html
spot99 is offline   Reply With Quote
Old 12-02-2012, 08:01 PM   #13
motornewbie
Junior Member
Thanks guys, I appreciate it!
Old 12-03-2012, 12:01 AM   #14
Manuel Azevedo
CF Senior Member
Manuel Azevedo's Avatar
You know it really doesn't matter what numbers are on that block. That engine is years old and completely unknown as to what it is and no Numbers at this point will tell you what it is other than maybe what it was how many years ago! Take it apart at lease the heads and oil pan and you can tell the bore size and then get a casting number from the crank, that will tell you what the motor is today!
Manuel Azevedo is offline   Reply With Quote
Old 12-03-2012, 12:55 PM   #15
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
...so how do I ascertain if this motor was originally from a corvette?...
It is not a Corvette engine; there were no FB codes in Corvettes. My hunch is that you have an Impala or truck engine.
Easy Mike is offline   Reply With Quote
Old 12-03-2012, 02:24 PM   #16
joewill
CF Senior Member
joewill's Avatar
you may want to think about other options and other engines. it is gonna be pretty hard to get 400HP out of a 327-235. sure it may already have some hipo parts in it, but needing rebuilt at best.
find you a 400 hp crate motor already done that is turnkey ready.. probably cost about the same.. especially after hauling you motor back and forth from your builder and waiting months for him to finish it.
also.. no such thing as a 400HP small block that has good low end torque. unless you really stroke it out to a 383 or more. you sacrifice one for the other.
joewill is offline   Reply With Quote
Old 12-03-2012, 02:55 PM   #17
BOSTONCAMARO
CF Senior Member
BOSTONCAMARO's Avatar
Joewill, could be a female machinist...just saying haha
but yes that is a good point...the biggest thing is the heads, spend 3-5 hundred at a shop, maybe more when you can get new aluminum heads for not much more
BOSTONCAMARO is offline   Reply With Quote
Old 12-03-2012, 04:09 PM   #18
builder
CF Senior Member
If the "guy" doesn't have paperwork to show it, he doesn't know what the engine really is....it's just another SBC.
Can that motor push 400 HP? It could, but without a dyno test.....We may never know. I personally doubt it.
builder is offline   Reply With Quote
Old 12-03-2012, 04:35 PM   #19
spot99
CF Senior Member
spot99's Avatar
My 2 pennies. If the car is gonna be a dirt racer, you would need tons of low end torque. Engine displacement is secondary. Cross pipes and a restricter at the back of the exhaust will help with torque. That's my first penny. My second penny would be to never drive a Corvette in the dirt. JMHO.
Reload this Page 69 327 Help please!
Tags
1968, 327, 3979910, 69, block, casting, chevy, corvette, heads, low, numbers, sbc, small, starter, torque
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Found a 68 L79 where it did not belong, what now? joebobo32 C3 Tech/Performance 5 10-01-2013 06:38 PM
1974 Vette(350ci MG/Crate 300HP) AlterEgoRocks C3 Tech/Performance 5 09-30-2013 04:17 PM
FS 1967 vette motor go bucks C1 & C2 Parts 0 12-09-2012 01:07 PM
67 327 motor go bucks C1 & C2 Parts 0 10-21-2012 06:16 PM
1967 327 for sale go bucks C1 & C2 Parts 0 10-17-2012 09:43 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
