Hood problems closing hood
As long as i have had my 78 vette over 15 years i have always had to drop my hood to get it to lock. I have never been able to just lower it down slowly and get it to lock..is this with every 78 or is their something i can do to make lock easy without slaming the hood down.
I have to do the same on my '81. All of the gaps are good around the hood so I do not believe it is an issue of it not being on the car correctly. I would be interested in hearing other owner's experiences too.
Mine is a pain also. I put it down gently and push each side down till they lock. Just the nature of the beast I guess.
The following 2 users liked this post by Ret.Horsecop13:
platinummaker (08-11-2020),
red topless gator (08-12-2020)
Received 1,470 Likes
Cruise-In II Veteran
Lower it to about six inches, then let it drop. Works on my '80.
Vader Vette
six or so inches high then drop it. if you do it the way your doing it now it will start to crack the glass in your hood.Ive never gotten my 77 or 75 hood to shut correct without doing the drop method ,If something works I stick with it!!!!!!!!!
Watch you hood bend when you just push one side down at a time.
St. Jude Donor '10
ren80 (11-30-2020)
From the movie Mr Mom: you're doing it wrong
I think the glass is strong enough that a small drop doesn't effect it. Lowering it then pushing, flexes the hood and makes it more susceptible to damage. The only bad thing about dropping it is when you are working on the car and forget to remove something that will block the hood and you drop it on that.
It's been that way even on the C4 and C5's I've had. ave to drop them to get them to catch
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
But as far has the 8 in drop I stopped doing this cause after I just spent a ton of money having the car painted and the underside of my hood done I have found crackes in the supports that go from side to side (fender to fender) where the holes are in the support...
most important!
Absolutely a must ... my '80 after day one, 31 years ago ... it works every time. the hood latches will not catch if the release is not pushed completely foward after unlatching. gently lower the hood onto the latches, then pull up and drop from about 8"-10" (18cm - 25cm) and it will not hurt the hood at all. no need to lube the latches either. no misses, cracks, warps ever. just thud and go.
Good news. My bonding exercise with my ‘68 is over! The hood is open! With the camera i was able to clearly see where i needed to land the ratchet wrench and I got the last bolt lose and the hood popped open.
Thank you to all that helped! It’s very much appreciated!
Dementer sole survivor
Received 6,369 Likes
2016 C3 of Year Finalist
Good news, unfortunately it got posted in the wrong thread. I think you went to far down and got into the "related thread" dark realm......happens alot
