Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-11-2011, 12:51 PM   #1
V8Ranger
CF Senior Member
V8Ranger's Avatar
Default Repairing glass t-tops
My driver side t-top has been rattling, turns out to be the glass loose from the inner frame on one corner. Sure would hate to see it peal off going down the road. My seals were also toast, got a new set from another forum member. I did some searching and didn't find too much, so I decided to just dive in and see if I can rebuild/repair myself.
The glass itself is ok, just some scratches on the outside that I may try to buff out. Main issue is the inner aluminum frame attachment to the glass.
Click the image to open in full size.
Before
All hardware loose, 4 studs supposed to be bonded to the glass are not.
Frame seperated from glass. Was glued around perimeter with something like butyl tape.
The 4 studs were no longer attached to the glass.
Got it all scraped and cleaned off. The blacked out area outside the frame appears to be a film rather than paint. Scraping it off left adhesive like removing window tint. The trim around the perimeter was dry rotted and will have to be replaced as well.
Bead blasted and repainted the aluminum frame.
More to follow soon...
Carl
V8Ranger is offline   Reply With Quote
Old 11-11-2011, 01:45 PM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
How did you remove the frame from the glass?
Easy Mike is offline   Reply With Quote
Old 11-11-2011, 01:53 PM   #3
mikejpss
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Location: Where it's always hot as Hell-South Louisiana.
Quote:
Think he said it was being held on by something like "butyl tape" ?? PO must have been related to Bubba ?
He's lucky he didnt loose the glass on a cruise....I would like to see how he attaches the bolts back to the glass, and is he gonna do the other glass so that they match ?
mikejpss is offline   Reply With Quote
Old 11-11-2011, 01:54 PM   #4
mikejpss
CF Senior Member
E X C E L L E N T WORK so far !
Old 11-11-2011, 04:27 PM   #5
V8Ranger
CF Senior Member
V8Ranger's Avatar
I am guessing it was butyl tape, it was the same consistency as the goo attaching windshields in older cars - but in straight segments like tape rather than 'caulk gun' application. It all appears to be original, I don't think anyone had attempted a bubba repair. The 4 studs will be reattached with rear view mirror glue.
If this turns out ok, I will definitely do the other side.
Carl
Old 11-12-2011, 10:32 AM   #6
Easy Mike
CF Senior Member
Easy Mike's Avatar
Quote:
Originally Posted by V8Ranger View Post
...I am guessing it was butyl tape...
That's why I asked. I'm looking at one now and there is no evidence of butyl tape. AIM shows the frames were cemented to the glass but is not clear exactly what type of cement was used.
I've been hoping to find a solvent for the factory cement.
Old 11-12-2011, 08:32 PM   #7
V8Ranger
CF Senior Member
V8Ranger's Avatar
I really couldn't see the cement until I had the frame seperated from the glass. I used a razor knife to cut thru the cement while pulling the frame away from the glass with my fingers (No prybars or screw drivers). Scraped with a razor blade and cleaned residue with laquer thinner.
Carl
Old 11-15-2011, 12:50 PM   #8
V8Ranger
CF Senior Member
V8Ranger's Avatar
Glued the studs on.
Masked off and ready to attach frame.
Glued down with Urethane and held in place by the studs.
I let it cure overnight at this point.
Carl
Old 11-15-2011, 01:16 PM   #9
V8Ranger
CF Senior Member
V8Ranger's Avatar
Trimmed around the frame with a razor blade, then peeled up the tape.
Cleaned glass, masked off where seal will glue and painted with flat black Krylon.
Ready to start attaching new seal.
Seal is on.
Here is where anyone else who trys this can learn from my mistake. Do Not put much tension on the studs! They are actually attached to the mirrior coating, not to the glass. Glass is not broken in this picture, just pulled a plug of the mirror coating loose. At this point, with the frame and seal glued on, I am going to live with it as is.
Perhaps in the future I will have them rebuilt with lexan to reduce weight.
Anyway, driver side is done and fit to the car. The new seal sure makes it harder to install the top, hopefully the seal will compress some with time and fit easier.
Now the passenger side...
Carl
Old 11-15-2011, 02:50 PM   #10
mikejpss
CF Senior Member
[IMG]http://i81.photobucket.
Carl
Yes, it will fit easier. When the rubbers are changed, it takes a few weeks for the new ones to "form fit" in their correct place. Make sure they go on correctly (rubber doesn't flip,warp,etc) then let them stay on the car for a few weeks. All the ones I've done I let stay on the car for a couple of months, then they went back easier. great job by the way! Looks good .....
Old 02-11-2013, 07:26 AM   #11
bdchase73
CF Senior Member
bdchase73's Avatar
I know this is an old post about the tops. But if anyone is out there, any idea where I can buy just the glass or lexan? I have a chance to buy some frames bu have no idea where to find the glass.
bdchase73 is offline   Reply With Quote
Old 02-12-2013, 05:42 AM   #12
V8Ranger
CF Senior Member
V8Ranger's Avatar
These folks still advertise rebuilt tops using Acyrlic, you can send the frames to them and they will build them up.
http://astrotops.com/gmtops.html
Reload this Page Repairing glass t-tops
Tags
1982, butyl, c3, corvette, gasket, gaskets, glass, lexan, reapairing, repair, sale, tape, top, tops, ttop, ttops
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New black C7 pics Stingray23 C7 General Discussion 180 03-31-2013 04:10 PM
Bubba said paint it San Diego Ron C3 General 18 03-26-2013 07:32 PM
99 Black/black auto coupe 47k miles Stingrayrob C5 Corvettes for Sale 10 03-24-2013 09:46 PM
Loose mirror San Diego Ron C3 General 8 03-04-2013 06:36 PM
Kerbeck T4T 2012 Lupigiato C3 General 2 10-07-2012 03:06 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
