Differential Fluid Question
7th Gear
Ziller pumped out all the differential fluid from the 1979 and replaced it with Royal Purple - Max Gear High - Performance Gear Oil (75w-90). The bottle sez that it is limited slip.
Question: Is this good enough? Or is the GM special formula and additive required?
Thanks in advance.
ziller
Thanks in advance.
ziller
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ziller..
I'm not a huge fan of Royal Purple.. but yes.. you'll need the additive. 1052358 is the old GM number...
I'm not sure of why you drained the rear but if the clutches were sticking and you have what we call "waddle" when turning corners then I would put two bottles in.. drive it in a parking lot doing figure 8's.. then drive it some more on straights... Drain and refill with standard old gear lube and 1 bottle of additive. If the clutches were sticking this should clear it up.. if not.. then you might consider pulling the rear and replacing the clutches.
IMHO,
Willcox
IMHO,
Willcox
St. Jude Donor '11
Ziller..
IMHO,
Willcox
IMHO,
Willcox
Received 1,888 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've run Royal Purple with no additives for years and it works great in posi's. Never seen anything but good stuff out of them so far.
JIM
JIM
[QUOTE=Willcox Corvette;1579022998]Ziller..
IMHO,
I added 2 bottles of additive when I had the same problem and it did the trick!!
IMHO,
Is there two questions there?
You ask about the differential drain plug but refer to a 79 automatic...no difference between auto and manual transmission regarding changing the differential fluid on a 79. I see the C5 logo so you may be assuming the transmission/differential is one unit as with C5 but this is not the case for C3.
So having said all that, the differential plug is on the passenger side above rear leaf spring. Should be a GM red tag that says "USE LIMITED SLIP DIFF. LUBRICANT ONLY" To drain the fluid you have to use a fluid pump or pull the cover which you do not want to do unless absolutely necessary...like you have a differential leak and need to replace the gasket
