Magnaflow muffler mods
Hi!
Has anyone modified his Magnaflow mufflers to make them louder?
I think itīs easy to decrease the Helmholtz resonator effect by pressing a slotted tube into the perforated internal tube to bypass the sound absoption.
What do you think?
Best regards,
Andreas
What do you think?
Best regards,
Andreas
Arent you increasing back pressure which is not what you want?
Hi,
thatīs the question...
http://www.magnaflow.com/02product/02muffler.asp
If you bypass the perforated straight tube inside it should be similar to a not existing muffler.
BR
Andreas
BR
Andreas
1. Your decreasing the inside diameter of the pipe, increased back pressure.
2. You are eliminating the expansion chamber that the muffler provides, increased back pressure and probably excess resonance.
3. If you dont want a muffler remove it and install a straight piece of pipe.
Vader Vette
I got a set of 40 flubmasters (Flow-masters) you wanna trade these things are nice and noise they are only one season old three shows maybe 500 miles they look new but sound like the sixty's.I have a 75 Corvette.
