U-joint squeaks...how to re-grease?
I honestly don't remember where I got mine from; I ordered a lot of parts from Duntov when I did my rear suspension and differential, but I think it may have been from Denny's Driveshafts in New York. If you find what looks like a cheap price make sure it's not for the greasable joints; I believe there are Spicer 1350 "series" joints that have a zerk.
What do you guys think? How can I visually tell if my half shafts are done or close to being done?
Also, when it comes to half shafts...would you go with original GM or these:
http://www.dennysdriveshaft.com/p1_1...aft.html#photo
http://www.duntovmotors.com/differentials-63-79.php
I don't plan on taking the car to the track...just street...pushing it...but still street.
One of those "ask me how I know's" - press the old u-joints out. Don't just start wacking with a BFH and hope they come out. The flanges are pricy.
Yup, those are the ones I'm getting.
But the question still is ... how to visually tell if half shafts need to be replaced? Is there a way?
If i only have to spend an extra $60-$70 and get a complete assembly with the shaft....I just might.
Actually, I should say they don't fail from STREET use; somebody on here used to have an avatar picture of a pair of halfshafts twisted up like somebody wringing out a towel!
There's nothing wrong with buying new if you want, but if it were me I'd spend some of that $70 on a can of Cast-Blast, freshen up the exisiting shafts, and put the rest of that $$ in my pocket.
Vader Vette
I have not heard of the rear end squeaking Ether but the turning at low speeds does kinda chatter but not squeak.But the fluid getting swapped out anyway so he will be tight when he gets her done.
