C3's with 18" wheels only thread
TTII's polished aluminum
BF Goodrich G force t/a KDW’s. The fronts are 17X8 245/45 4”BS and rears are 18X10 275/40 5.5”BS
1 coil cut from the OEM 550Lb springs in the front. Dual mount VBP spring in the back.
The following 2 users liked this post by binster:
amandico82 (03-02-2021),
mysticpete (07-27-2020)
It's more like what's not modified... VanSteel Tube A-Arms upper & lower, with single adjust QA1 coilovers w/500# springs. VanSteel offset TAs with dual adjust QA1 coilovers w/ 600# springs on the rear. Lowered ~3".
The following 2 users liked this post by Ray Y:
halleyro (11-24-2019),
Laws69cars (01-22-2016)
related question
I was hoping to put my C6 wheels and tires (18/19's) on my `73 . . how much messing around am I going to have to do at stock ride height....figure I'm going to need some spacers to square up offset, but size-wise, should fit under the fenders??
Any advice is appreciated . . .
Rebelrob,
It looks like you have 18" Coy C-5 wheels. My BOSS 338's are similar. What is the backspacing of the 18x9.5's in the rear? 5" or 5.5"? Did you need to relocate your parking brake cable?
I have 18x8/4.5 bs front and back. I just added 1/4" spacers to get some of the 1/2 backspace back, but I also want to replace the 18x8 with 18x9.5 in the rear.
The following 2 users liked this post by bluegtp:
senseibruce (07-27-2018),
TRT SR (02-10-2021)
#35
The following 3 users liked this post by RobbSalzmann:
#38
[QUOTE=MN80Vette;1578746379]Rebelrob,
MN80Vette,
Yes, they are similar in shape. Made more sense since I do not have any chrome on the car. More muscle look I guess. I am happy with them. I got 5.0 rear BS and factory 4.0 BS up front. I got 285 tires on the back. Just cinched down the parking brake cable with a plastic zip tye. No rubbing, but sure is close to the rear spring ends. Planning on a VB&P new stiffer shorter spring. Some members out their have the 5.5 rear BS with 285 and I hear it can rub at times pending on your suspension in the back. Another thing to point out is I got 3:54 gears in the Dana rearend, which actually has a tad longer stub axles that push the tire out a bit, I prob would have been ok with 5.5 bs in the rear.
MN80Vette,
