C3's with 18" wheels only thread
#642
Not many of us with 18/19 combo. What size tires front and rear? Current tires on my wheels are 285/35/19 and 245/40/18 front, but have a set of 285/40/19 and 245/45/18 sitting in the basement and not sure which to run.
(Car is not completed or finished yet to test or have an accurate look)
#647
[QUOTE=tektrans;1592730572]
For sure. Would like to know the color or see some other shots of it.
(but my OCD is bothering me that they did not black out the rear gill)
#649
Not 18's, but I really like my 17's. 17x9.5, with a 255/50r17 tyre on all 4 corners. -5mm offset, basically 5" backspace. I can understand why people chose 18's, as I had to shorten the rear spring, move the handbrake cable mount to the top of the trailing arm, and run a tiny 3mm (1/8") spacer on the front to avoid rubbing the tie rod ends when cornering hard. All of these would have fit inside the wheel on an 18 and not been a problem... I also had to reshape the rear sway bar slightly to avoid rubbing the tyre.
#650
Here is my 74 with US Mags Rambler U111's. 18x8's with 4.5 backspace up front 255/45 tires and a 1/4 spacer. 18x9.5's with 5.25 backspace and 285/40's out back with no spacers. Had to re-locate parking brake bracket. Let me tell ya it's pretty tight in there. About an 1/8 of an inch from the frame at full compression and about 1/4 from trailing arm but no rubbing issues so far and they tuck nicely under the fenders.
Xanthophyll (03-14-2020)
#655
Product Information: 4 (77241) Vision
18 X8.5 5-120.65 -6 DGMTML
Torque
4 (26961) Continental
255 /45 R18 103Y XL BSW
ExtremeContact DW
1 (80300-77241) WHL INSTALLATION KIT GORILLA WHL INST. KIT
Total Price: $1,364.56
Testing the fit. No spacers, they just fit fine:
Done:
What a difference in handling and high speed stability! Previously I had Cooper Cobra 275/60R15 rears and some no-name 225/60HR15 front tires. Still have the wheels and tires, I suppose I'll put them on craigslist.
Torque
ExtremeContact DW
Done:
#656
Torque
ExtremeContact DW
Done:
Torque
ExtremeContact DW
Done:
#657
Torque
ExtremeContact DW
Done:
Torque
ExtremeContact DW
Done:
