Cam for my 72 350
Cam for my 72 350
I want my Corvette to chop and thump at idle. Compcams says that I have to change out the valve springs. I didn't want the expense of taking off the heads. Any ideas? Thanks Tom
You can change the springs without taking off the heads. You can buy the tool at your local parts house most likely. Put air pressure in the cylinder to keep the valves from falling.
You don't have to change the springs.
Get a cam with like 480 lift and 280 duration at 110 lobe separation, a nice double row timing chain and be happy.
I know what Im talking about I have ran all kinds of cam on the street.
But if you want go ahead and spend $1000 on a cam change and get the same results.
Stock springs have around 85 lbs seat pressure. CompCams #981 spring, has 105 lbs.
Get a Comp Cam kit with timing chain and valve springs. Those stock springs will fatigue with a cam with a high lift. How old are your springs now? 29-30 yrs old?
Follow CompCams advice. They have done more testing than most of us here.
So now he is discouraged from doing anything.
If you pull the heads and refreshin them then the next thing to wear out is the rings from the new sealed heads.
Instead of a cam change just pull the engine and add a $10000 LS engine and while your that far rebuild the trans, no better yet add a 6 speed and pull the body off the frame and rebuild the whole suspension and interior.
Over thinking never helped anybody.
Just sell the car and forget the whole mess.
I agree. There are also great videos on youtube that will walk you through how to use the compressed air to keep the valves up, how to remove and replace the seals, etc. It sounds complicated, but watch the videos and you'll be surprised. Just take your time and you'll be fine. GL!
If you are putting a new cam in you already have the intake off. The extra expense is exhaust and head gSkets right? Not that much more in the grand sceam of things.
Kelley
Kelley
The air compressor isnt even absolutely necessary.
You can bring the pistons to TDC for each cylinder, and insert a rope into the combustion chamber through the spark plug hole to hold the valves up.
Using air is easier, but if you cant come up with a compressor you still have options.
OP, listen: big rumpety-rump cam + raggedy old valve springs = valve float. Valve float is bad. Put new springs in the heads, it's not that bad of a job, and you might actually be able to rev the engine high enough to use the cam.
You could save a bunch of money and just play with the idle screws on your carb and the spark timing till it idles all screwed up, and just tell people you have a big cam.
Scott
If you are swapping a cam, this is really the only additional tool you will need to change out the valvesprings. You can probably even borrow one from somebody. Oh, and some nylon rope, to stuff in thru the spark plug hole to keep the valves up while the springs are off, 20 feet of 1/4" or 3/8" should be way more than enough. I wouldn't bother taking the heads off unless there is a reason to, that turns into a pretty big job, cleaning the gasket surfaces, etc.
http://www.jegs.com/i/Manley/660/41830/10002/-1?CT=999
Scott
Scott
What's the big deal with taking the heads off? I did a head gaskets on a 6.5 diesel, it isn't that bad to do, and I guarantee it is half the work on a vette.
