78 pace car project/ carb fitting?
Old 01-15-2017, 07:42 AM
steve78vette
steve78vette's Avatar
Default 78 pace car project/ carb fitting?
Hi folks, question number 2,00456.
I have my stock L48 engine back together
(purchased in pieces) and am know trying to figure out what fits where
(also live on an Island sooo there is only one other vette to look at close by. and it is a 69 with different carb.
Anyway wondering what connects to the back of the Quadrajet base { looks like a vacuum line?)
Any help would be great.
Thanks,
Steve
Old 01-15-2017, 08:05 AM
steve78vette
Old 01-15-2017, 08:19 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Originally Posted by steve78vette
...Anyway wondering what connects to the back of the Quadrajet base { looks like a vacuum line?)...
Vacuum supply for power brakes. FWIW: the assembly instruction manual and GM shop manual would probably be a big help for you.
Old 01-15-2017, 08:42 AM
steve78vette
Thanks, I have a fitting coming from the power brake booster, but it is a plastic (push in) 90 degrees. Soo I must be missing some kind of connector.
Thanks for the help.
Steve
Old 01-15-2017, 09:14 AM
Easy Mike
Easy Mike's Avatar
...Soo I must be missing some kind of connector...
Carb fitting, metal tube, and bracket. Pic is 74, but 78 will be similar.
steve78vette (01-15-2017)
Old 01-15-2017, 09:55 AM
steve78vette
Mike, You ARE the man , looking at this solves several questions!
Found the bracket I was missing still attached to the old transmission,
and also I have that split vacuum tubing just did not realize where it went.
Thanks,
Steve
P.S. Don't be makin' fun of my (in depth, really good, expensive) Haynes service manual!
Old 01-15-2017, 10:01 AM
steve78vette
Old 01-15-2017, 10:16 AM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
Toss the Haynes in the trash, and buy the GM shop manual for 78.
Old 01-15-2017, 01:30 PM
steve78vette
Yeah good advice,
and don't buy used cars in pieces!
Thanks,
Steve
Old 01-16-2017, 04:20 AM
hunt4cleanair
hunt4cleanair's Avatar
Steve
In addition, the 78 carb had a port at the bottom (backside) with a small hose that ran to the air cleaner. That would be missing from the photo.
Old 01-16-2017, 07:19 AM
steve78vette
Okay thanks,
I thought that small one went to the advance on the distributor.
I have been looking at lots of pics. Lots of after market intakes and different arrangements.
Thank you for the help,
Steve
Old 01-17-2017, 04:15 AM
hunt4cleanair
Okay thanks,
Here ya go!
emission hose schematic
steve78vette (01-17-2017)
Old 01-17-2017, 05:23 AM
steve78vette
Wowzer! Going to be fun to figure out what to keep, what to close off, what to kill.
By the way I live in Harkers Island NC (beginning of outer banks) Good to see Myrtle Beach represented.
Thanks for the info!
Steve
To 78 pace car project/ carb fitting?
Quick Reply: 78 pace car project/ carb fitting?
