Goodbye Big Block/4spd...Hello LS2/6speed...
#142
Tach
I used a Dakota Digital tach interface. My harness had an input from the ECU. I converted my 70 mechanical tach with a 75 electric tach that plug right into the Dakota. You have to select the correct 4 cylinder cycle since the ECU puts out half the signal. It seems to work in line with my scanner, but I have to drive it still.
#144
Gordon, not sure what tach you're running but I have an Autometer ultra lite #4498. For this model it calls to reduce the pulse by clipping the Brown and orange wires. Problem is, I do not see Brown or orange wires coming out of this tach.
Looks like I will be calling Autometer tomorrow.
#145
Corey, these are the instructions I pulled from auto meter for the 4498. It says that you change the setting by way of switches, but it also says that it's factory shipped for use on 8 cylinder use. Check to see if yours is this way, if not it may be defective.
http://www.autometer.com/productPDF/1185.pdf
Terry
Terry
#146
I thought I had the switches but couldn't see then until I removed the tach. They are really, really small and had to use a toothpick to change the seetings.
#147
Finally able to drive the car today, tack is fixed and accurate. Tried to recalibrate the speedo again, still does not go too full sweep only 3/4, but if it's off it's not by much. I'll test it against my gps.
#148
I did this 10 years ago ( Yikes ) with an LS1 & T56.
It's much easier now, back then there were very few parts being made for these swaps.
It's the best thing I ever did -
Happy Motoring
Frank
Happy Motoring
Frank
#149
Glad to see the tach problem resolved. Now its time to drive and enjoy it. The ls motors are a really nice upgrade for the C3's
Im going tomorrow to have mine retuned, looking to gain a few more horses and clear up a few things in the current tune.
Terry
Terry
#151
Put 40 miles on her today,.speedo is only off by maybe 2mph per the GPS, I can live with that considering the stock gauges in ourr cars are not terribly accurate in the first place.
Second the cooling system held up like a champ, most of the drive was moderate to having traffic. At one point I had to sit through 3 red lights. The temp never got above 205.
Gordonm (05-23-2020)
#153
After 30years, paint is looking tired and is in for a nip/tuck. Project took longer that anticipated but they do fantastic work, paint should go on today or tomorrow.
Changing the color, will be quite a difference in hue.
Hopper12 (03-18-2021)
Corey_68 (05-04-2021)
Corey_68 (05-18-2021)
#159
Received 3,043 Likes
St. Jude Donor '05
So looking back what are the pros and cons in your opinion of both powerplants?
