Did anyone else have to trim carpet this much?
I just ordered a new carpet set from Wilcox, but manufactured by mid america. I went to install the wheel well area and this is what it looks like as of now. I didnt want to trim yet because it just seems like a ton. Also, any tips for trimming these jokers? I have some heavy duty scissors, but i need some help as how much i need to trim and all. I dont have my old carpet when i removed everything from the car in may i was a little trigger happy to throw what i didnt need anymore away haha
here is a pic of the wheel wells
I believe with carpet, you want to use a utility knife on the back. You don't want to cut from the front side, or with a scissors, because you will cut the loops and the edge won't come out as nice and it will unravel easier. Talk to a carpet installer about it.
try really sharp tin snipes...... also are you sure you have them on the correct sides?....
Received 1,470 Likes
Cruise-In II Veteran
Are you sure you have a carpet set for a 77?
Some trimming is expected, but the wheel house carpeting in your pic seems to be way too big.
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,468 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I just installed carpet in my 82 also from Willcox. A good utility knife works well. Make sure you keep fresh blades in it. When the knife starts to not cut as well change the blade. I did not have excessive trimming to do. My complaint was the cargo door opening was not precut. That took some extra time to get right.
There's plenty of material to trim off - a GOOD thing. IMO, how much is not an issue. Not having enough carpet to fit or cutting it too short IS a problem!
Take your time, buy a quality carpet knife and a pack of quality spare blades, and you'll get it done. Be careful...I don't believe there are many blades in this world sharper than a carpet knife blade. OH! And I bout gave up on that 3M carpet spray adhesive in favor of that green carpet glue MA sells. (some really good stuff!)
P.
Received 2,878 Likes
Hi,
I agree that TOO MUCH carpet is far better than TOO LITTLE.
I found that using a scissors is better than a knife because it gives more control of the cut.
I bought a scissors that had blades that were about 1/2 the length of regular household scissors. This made the carpet easier to cut and the short blade helps to make precise cuts.
You can see the scissors I bought and a regular scissors that I also used for some cuts laying on the carpet in this picture.
Regards,
Alan
Regards,
Alan
Measure twice, cut once. You can always trim it a little smaller, but ya can't trim it any bigger. Leave an inch or two extra until the whole thing is done, in case ya need to tug and pull here and there.
Scott
Scott
Alan, did you leave that much carpet under the sill plates, or was the picture taken before you trimmed? I'm carpeting once the paint's done.
Cheers
Grant
Cheers
Grant
In my case, I left a bit more than that. In fact, I cut "V" notches in from the edges to expose the holes for the sill screws - affording as much adhesive purchase as possible. Sills (new) fit just fine.
P.
I also got my carpet from Willcox & my entire rear section was one piece.
I got the one that Tom said was the best one to get, all pre cut, very little trmming.
I tossed the box, A1 or something. I saw anoteh restorer on this forum had a pic of it in his thread.
And I left about that much under the sill plates as shown above as it was trimmed, sealed & has plastic going from front to back with the holes in there for the sill plate screws to line up with.
I really gotta get off my butt, take some pics & post them here.
