Courtesy Panel Lamps - 69 corvette
What are the part numbers for the courtesy panel lamps on a 1969 Corvette. What are the specified amps and volts for the Courtesy lamps on the the dash. Thanks
Ed Frye
Ed Frye
Received 1,470 Likes
Cruise-In II Veteran
The owner's manual lists all the lamps. None can be more than 12 volt; not sure on the amperage. IP lamps are probably not more than 3 or 4 candle power.
i believe the bulbs are a number 90
