Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-01-2011, 11:43 PM   #1
Rollochrome
CF Senior Member
Support Corvetteforum!
Rollochrome's Avatar
Default Rear Speaker Enclosures / Setup Recomendations for my 79
I want to accomplish two things..........
1. Maintain the rear deck sufficient to store the T-tops
2. Install a system with good thump..
In a space as small as the interior of a 79 Vette.....I believe that you can accomplish good bass response in a small woofer.....if done with the proper enclosure.
Has anyone come across a prefab rear speaker enclosure that you would recommend?
OR......
Any that you would tell me to steer away from??
Rollochrome is offline   Reply With Quote
Old 06-02-2011, 01:00 AM   #2
onaqwst
CF Senior Member
onaqwst's Avatar
i would get a good set of 6x9's (or 2-way component set) and a 8" sub (in a ported box built into one of the rear compartments) with a 3 channel amp....find an amp with a sub output and you should be fine..... somewhere around the 600watt range 3x200 or so will work
onaqwst is offline   Reply With Quote
Old 06-02-2011, 05:37 AM   #3
dgood
CF Senior Member
Try this....Boss Audio BASS1500 from onlinecarstereo.com. 170 bucks and quick to install. I got a set of kenwood 6x9s in the rear and a pair of 160 watt 4x6 speakers (20 bucks) in the dash and a pair of 160 4x6s in the kick panel. Cheap, and easy. I have an aftermarket stereo in my car. I bolted it up against the back wall in my 79. It won't knock the windows out of the car but it is very loud once I got it adjusted right. Real good bass also.
dgood is offline   Reply With Quote
Old 06-02-2011, 08:17 AM   #4
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
FWIW: the optional factory rear speaker set up runs a pair of 6x9s. AIM shows the installation and the parts (two brackets and two grilles).
Installation will not take away any space in the rear.
A small amp can be tucked in the space in front of the battery or the jack compartment.
Easy Mike is offline   Reply With Quote
Old 06-02-2011, 11:14 AM   #5
dembo
CF Senior Member
dembo's Avatar
Get a amp+sub combo, and space lost is minimal. It will not shake your neighbours windows but is plenty powerfull for a deep thump inside the car
Nick
Click the image to open in full size.
dembo is offline   Reply With Quote
Old 06-02-2011, 11:34 AM   #6
rudolph schenker
CF Senior Member
rudolph schenker's Avatar
rudolph schenker is offline   Reply With Quote
Old 01-11-2012, 12:58 PM   #7
Shark Racer
CF Senior Member
Shark Racer's Avatar
Send a message via ICQ to Shark Racer Send a message via AIM to Shark Racer
Rudolph - I really like your setup. Where do you keep the amp?
Did you run the box all the way out to the wall or are the kickups that go over the wheel arches mostly aesthetic?
Shark Racer is offline   Reply With Quote
Old 01-11-2012, 01:24 PM   #8
Kaos
CF Senior Member
Kaos's Avatar
I have same box as Rudolph. Its a great box for $99 shipped and I would have gone with the 10" woofer if I had realized I could have added the woofer 1" trim ring spacer increasing the sealed box air volume. With Infinity Kappa's & woofer and my alpine 5 channel amp (under front passenger seat) this is a nice setup and the bass surprising hit really hard & low. Had to turn down the power to the subwoofer actually to balance it all out. I had a Kenwood shallow mount 8" woofer & JBL's but that sounded like crap.
This fits perfect with top down in my 69 convert.
Kaos is offline   Reply With Quote
Old 01-12-2012, 12:14 AM   #9
Shark Racer
CF Senior Member
Where did you get it from, Kaos?
Old 01-12-2012, 09:29 AM   #10
Kaos
CF Senior Member
Kaos's Avatar
They sell them on eBay. Search "c3 speaker box" and you shall find a shop in Orlando sells these for $99
Old 01-12-2012, 08:43 PM   #11
Stroh
CF Senior Member
Stroh's Avatar
I'm redoing my interior right now incuding a speaker box. They're easy and way cheaper than 99 to build. After I get the Dynamat and Reflectix sound and heat dampening down this weekend, I'll do the box. I'll post pix as i go. You might want to consider pointing the Sub down (or back) for lows that sweep around you instead of change your heart beat. And if you go with seperates, put the tweeters up high for clarity in the highs. That C3 cockpit is pretty tiny. I'm not sure I'll even mess with the dash speakers. Looks like a PITA. Good luck.
Stroh is offline   Reply With Quote
Old 01-12-2012, 11:47 PM   #12
Drawmain
CF Senior Member
Drawmain's Avatar
Quote:
Did mine for 30 bucks in a day, I ran a Punch 10", plenty of thump. I'm partial to Infinity for the 6x9's, and put a pair of 4x6 plate speakers in the dash. Sounds pretty good, and the front speakers are not hard to get to in the 78-82 dash. I'm short so I could mount the amps behind the seats, used a four channel for the dash and rear and a Fosgate for the sub. Oh, and the 30 bucks was for just the box, not the drivers, lol
Drawmain is offline   Reply With Quote
Old 02-01-2012, 09:23 AM   #13
SonnyLynnVick75
CF Senior Member
SonnyLynnVick75's Avatar
Im running two 4x6s in the dash, 2 4x6s in the kick panels, and a custom box in the rear it mounts to the back wall with about 4-5" clearance underneath it for storage. I built the box 36" wide andi've forgotten depth and width out of 3/4" plywood. wrapped it in vinyl and dyed medium saddle. mounted two 6x9 pioneers with beige gaurds and a 400 watt amp in the middle of the two with a medium saddle front cover with the 75 emblem in the middle. if you email me at slvick@tva.gov ill send pics. I have two power acoutiks 10s in my daily Suv so when i get in my vette im normally looking for a break from bass and love the sheer loudness of pure music.
SonnyLynnVick75 is offline   Reply With Quote
Old 02-01-2012, 09:34 AM   #14
Bowerss2
CF Senior Member
Bowerss2's Avatar
here is what i did i did not use a sub but a pair of kenwood 4 way 6X9s and kenwood dash speakers the location of the dash speakers is not ideal but it sounds amazing and best of all the t tops fit like they should.
i used cardboard to mock up the speaker boxes
i bought some nice leatherette that i dyed to match the oyster
i put some thin padding under the leatherette so they look nice
Final install
i did reinstall the speaker grills over these it fit fine.
Bowerss2 is offline   Reply With Quote
Old 02-20-2012, 01:38 AM   #15
dmruschell
CF Senior Member
Bowrss2: I'm strongly considering a setup very much like yours for my newly acquired 79, but am a newbie at this kind of stuff. I have two questions:
1. How did you attach the amp to the area behind the seat?
2. How did you attach your 6x9 speaker "boxes" to the car?
Thanks in advance!
dmruschell is offline   Reply With Quote
Old 02-21-2012, 12:32 AM   #16
addballer696
CF Senior Member
addballer696's Avatar
heres a thread from a while ago, but some good ideas. Mine still bumps fine and def. gets the job done. No space taken up, just dont have a jack anymore.
http://forums.corvetteforum.com/c3-g...-progress.html
addballer696 is offline   Reply With Quote
Old 02-21-2012, 07:12 AM   #17
KevinG
CF Senior Member
KevinG's Avatar
ArcticDC5
Quote:
This is what I will be doing, but my 10" will protrude slightly above the rear deck floor. Good workmanship
KevinG is offline   Reply With Quote
Old 02-21-2012, 08:21 AM   #18
Stroh
CF Senior Member
Stroh's Avatar
Sweet set-ups. Love the fuzzy dice.
I posted a thread on the box I built on here, but it looks to have been deleted??? Anyway here's another way of going about it.
We built a speaker box for probably $30 (press board, carpet, polyfill, adhesive, etc) way cheaper than buying on ebay. I think dimensions were 35x12x14. I'd probably go a little thinner if I did it again.
Built the amp, crossovers, and woofer on the back of the box.
Then put the tweeters and speakers on the front og the box.
It's nowhere as impressive as the unbelievable fiberglass system enclosure I've seen here, (under the title "custom fiberglass interior (many pics)" by member 2000frcz19),
but it should do the job. I'm curious to see if the T-tops will still fit in mine or not. It'll be close, and since it wasn't a deal breaker for me, I guess it will just be gravy if they do.
Good luck with yours.
Old 05-10-2012, 09:00 AM   #19
Dose11
CF Senior Member
Dose11's Avatar
Any specs on how you built this box???
Dose11 is offline   Reply With Quote
Old 05-10-2012, 01:53 PM   #20
79L48
CF Senior Member
79L48's Avatar
This is the inside of the MDF box I built. You can see the 6" little sub on an angle mounted in the chamber next to the amp.
Here it is installed. Plenty of room for T-tops and other small bags. The box is easy to remove if needed. The sound is good enough for me, though I admit it is not a "high end" system. All with new deck, new dash speakers, new amp and sub, and the box materials I am in for less than $300.00. The 6x9s I had. I hope to upgrade them later.
79L48 is offline   Reply With Quote
Reload this Page Rear Speaker Enclosures / Setup Recomendations for my 79
Tags
1979, box, boxes, c3, car, corvette, custom, enclosure, enclosures, marc, rear, speaker, speakers, version, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
