Rear T-Top Latch
Rear T-Top Latch
I have my 75 coupe at the body shop getting them to adjust the t-tops and windows after I intalled new weather stripping. The back edge of the t-tops sits a little higher than the roof line just behind them. The shop called me today and said that the car does not have the striker plate that the latch striker contacts.
Can someone post a pic of the area where the rear latch striker contacts? Thanks
Received 2,878 Likes
Hi t,
The rear outer corner of the roof panel is located and locked by 2 different pieces.
Hope this helps!
Regards,
Alan
This locates it....
This is what the latch compresses against...
Hope this helps!
Regards,
Alan
This locates it....
You're in luck! Went to the garage and checked and have the pair if it's the part in the second photo. Triangular piece that screws to the body and top trim screws to. Email me your adress and I'll send em to ya. mickcore@yahoo.com
Hold Up Folks. Got the AIM out and found a part number. Do they have a part number of 3948067 and 3948068 stamped in them? If so, I found mine. I was thinking of something totally different. Let me know if that is the right part number for what I need. Appreciate all your help.
Hi tim,
I believe the wedge and plate are being reproduced, but not the striker plate. I do see some available in various vendor's catalogues though.
Regards,
Alan
Regards,
Alan
