Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-22-2011, 03:54 AM   #1
MCMLXXX
CF Senior Member
St. Jude Donor '14
MCMLXXX's Avatar
Michael Beatt @gearjammer228
Default 1980 fuel tank question?
Hi guys,
Got a question about my 80s fuel tank.
Did the 1980 have a bladder inside the tank?
when my fuel gauge gets down to 1/4 tank I fill up, but can only get around 13 gallons in the tank, and the 80 is supposed to have a 23 gallon tank. so is it my fuel gauge? or is the bladder(if it even has one) messed up. if i still have 10 gallons left in the tank the gauge should read somewhere close to 1/2.
Thanks,
Mike.
MCMLXXX is offline   Reply With Quote
Old 04-22-2011, 05:15 AM   #2
c3corvettes
CF Senior Member
c3corvettes's Avatar
Might require some basic electrical troubleshooting between the fuel sending unit and the fuel gauge. You could also go the other route of trial and error. Replace sending unit inside tank. Then replace fuel gauge if problem still persists. Someone more knowledgeable on the forum will chim in and help you out. Hang in there. I'm not sure what the "bladder" is...
c3corvettes is offline   Reply With Quote
Old 04-22-2011, 09:03 AM   #3
qwank
CF Senior Member
qwank's Avatar
I had the same question. When my low fuel light comes on, the needle is pretty much at dead empty, but it only takes 19 gallons to fill it.
qwank is offline   Reply With Quote
Old 04-22-2011, 09:26 AM   #4
gbvette62
CF Senior Member
gbvette62's Avatar
GM claimed that the 80 tank was 24 gallons, not 23, and yes it did have a bladder in it.
My guess would be that you have a problem with either the gauge or the sending unit.
Usually if you have a leaking bladder, you will run out of gas, with the gauge still showing gas in the tank. Fuel that leaks out of the bladder, ends up trapped between the steel tank, and the rubber bladder. When this happens, you end up with 5-10 gallons of fuel trapped under the bladder. As you use the fuel up, the the sending unit's float keeps dropping. At some point it will come to rest on the bladder. The gauge will show a 1/4 -1/2 tank of gas remaining (it is there, it's just under the bladder), yet the car runs out of gas, because there is no fuel left in the bladder to pick up.
I won't say that you don't have a problem caused by a leaking bladder, but if you had 13-14 gallons of gas trapped in the tank, I think you would run out before the gauge got down to a 1/4 tank.
gbvette62 is offline   Reply With Quote
Old 04-22-2011, 09:46 AM   #5
bozzman3
CF Senior Member
bozzman3's Avatar
I could be wrong,but I recall reading somewhere that Gm would set up the fuel supply system with a 2 gallon reserve.When the gauge read empty there was still 2 to 3 gallons left.I have a low mileage 1980 and when its almost at empty it only takes about 17 to 18 gallons.I thought it had a 18 or 19 gallon tank!
bozzman3 is offline   Reply With Quote
Old 04-22-2011, 11:03 AM   #6
qwank
CF Senior Member
qwank's Avatar
Quote:
so mine must be correct then. when the light comes on, there 5 gallons left.
Old 04-22-2011, 11:26 AM   #7
MCMLXXX
CF Senior Member
St. Jude Donor '14
MCMLXXX's Avatar
Thanks guys, That narrows it down for me then. i am sitting on empty right now so when i fuel up I will see how much i can get in there.
the owners manual shows it being a 23 gallon tank, So that is what i am going off of. I was hoping it was something like the sending unit and not the bladder. Thanks for the help!
Mike.
Old 04-22-2011, 12:38 PM   #8
Grumpy 427
CF Senior Member
Grumpy 427's Avatar
Send a message via MSN to Grumpy 427
I have an 80 vette, and my gas tank was a plastic fuel cell inside and not the bladder. I was greatful i didnt have to deal with that bladder BS. I wonder if there was a change part way through the build year?
Grumpy 427 is offline   Reply With Quote
Old 04-23-2011, 03:22 AM   #9
KENS80V
CF Senior Member
KENS80V's Avatar
78 to 82 tanks have a plastic liner inside the tank. They don't shrink like the rubber bladders did in past models but they will eventually dry rot and split. Replacement tanks do not have the plastic liner.
First thing I'd try is a can of Sea foam or Techron in the tank. It might clean up the contacts on the sender.
KENS80V is offline   Reply With Quote
Old 04-23-2011, 10:19 AM   #10
'75
CF Senior Member
'75's Avatar
I just had a 78 tank out and it has plastic on the inside. The plastic is actually pretty thick and the metal on the outside is very thin. It reminds me of a plastic tank with a thin metal shell. I think the plastic is too rigid to collapse like a rubber bladder would. I can't imagine it would get very much fuel between it and the metal shell even if it split.
'75 is offline   Reply With Quote
Old 04-23-2011, 06:29 PM   #11
Yellow1980
CF Senior Member
Yellow1980's Avatar
When my 1980 gets down to 1/8th it takes 16 gallons to fill it up. So it sounds like that may be normal for a '80.
Yellow1980 is offline   Reply With Quote
Reload this Page 1980 fuel tank question?
Tags
1980, bladder, c3, capacity, change, corvette, fuel, gas, install, polyethylene, sending, size, tank, tanks, unit
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
