Transmission Fluid (gear oil) replacement cost
Old 04-19-2018, 11:06 AM
~Stingray
~Stingray's Avatar
St. Jude Donor '17, '19
Default Transmission Fluid (gear oil) replacement cost
Hey guys,
I have the car (1980) in the shop to do some things I don't have the tools for, like repacking the front bearings.
While it is in there, I thought I would have the transmission oil changed as discussed in another thread. The guy wants to charge me $50 for the oil and labor. Is that good? Most of my standard oil changes for my mustang/corvette are around $20-25 so I was surprise to see it be double.
I would do this on my own, but now I don't have to worry about the mess or disposal.
Thanks.
Old 04-19-2018, 11:36 AM
Cooter Tech
Cooter Tech's Avatar
Originally Posted by ~Stingray
Hey guys,
Thanks.
Automatic with filter and gasket not out of line. 4 speed maybe a little high, still paying for mechanics time and supplies, but you have to smell like a cat litter box for the rest of the day, that’s worth something too. Gear oil stinks.
Old 04-19-2018, 11:56 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Is it worth $50 to you to have the shop do it?
Old 04-19-2018, 12:05 PM
Bikespace
Bikespace's Avatar
Received 3,148 Likes on 2,336 Posts
I easily spent twice that on fluid, and the tools to do it correctly (manual). But now I can do it a few more times for free.
I hate the smell, too, but the full synthetic isn't as bad.
Old 04-19-2018, 12:53 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
A tool for repacking the front bearings??????????
Who told you there was a tool to repack the front bearings especially the inner one???
A quick summary is, you remove the wheel, remove the brake caliper, remove the rotor, clean the bearings of any old grease, slap some grease in your hand and work the grease into the bearing. Reassemble everything.
Old 04-19-2018, 12:56 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
It takes a crescent wrench and 2 quarts of oil (dino gear oil is $7/qt. and syn gear oil is $13/qt.). How did you spend $50??
Old 04-19-2018, 01:02 PM
Bikespace
Bikespace's Avatar
I bought a lifetime supply of Redline, $60. A pump attachment, $10, and a sucky thing for the diff, and a hedge against a stuck plug (also works for the Power steering reservoir), $20-. Add some paper towels and tax and you are at $100-.
I also have a Lisle 34550 Handy Packer tool to the other comment. Works great to displace the old grease. Push down ustill the new grease flows.
Old 04-19-2018, 01:40 PM
ddawson
ddawson's Avatar
Manual? Does it have a drain?
$50 is not out of line in California. In fact that would be cheap.
My Muncie didn't have a drain so it's a suck and fill. Takes more time.
Packing by hand is easy but the tool makes it super simple. I also like the took to force all the old grease out for a repack.
Old 04-19-2018, 02:59 PM
SIXTYTWO
SIXTYTWO's Avatar
Hey guys,
Thanks.
Most decent shops have a labor rate between $75.00 and $100.00 an hour. It doesn't take much time or material but $50.00 is probably average.
Old 04-19-2018, 06:03 PM
calwldlife
calwldlife's Avatar
St. Jude Donor '22
50 sounds reasonable
Old 04-20-2018, 07:23 AM
~Stingray
~Stingray's Avatar
Actually, a mechanic friend of mine said it takes a lot of time, need the right tool or it takes longer (I thought a press was needed) and if you don't put it together right you could have catastrophic problems when you go for a drive. Obviously that description could be said for a lot of things. I mean remove the time factor and the same could be said of lug nuts. But I hadn't done it before and his description scared me off of it.
Old 04-20-2018, 11:45 AM
MelWff
MelWff's Avatar
Your friend was referring to the rear bearings. The front are the same as millions of Chevrolets, Pontiacs, etc., no special tool or press needed. It might be advantageous based on this thread and others you have posted to invest in a copy of the factory shop manual and read through it. It is the best source in the world next to this forum on learning about your car.
To Transmission Fluid (gear oil) replacement cost
Quick Reply: Transmission Fluid (gear oil) replacement cost
