Help! Need '75 AIM page for Power Window Harness, now...
Thanks to a helpful forum member I was able to get the AIM pages for the '73 - but it turns out my harness is from a '75! I didn't realize they are different.
Hopefully I can get the '75 AIM pages and see what's different about the install...
Thanks in advance!
Thanks in advance!
Received 1,470 Likes
Cruise-In II Veteran
Well the power window harness is different. Looks like Wilcox sells 2 different ones, and 75 is the split.
According to the '73 AIM, there is a wire that goes outside a grommit in the firewall, and connects to the horn relay.
However, there is no such wire on the '75 Harness. So I'm trying to see how it's connected in '75 and hopefully I can adapt to '73. I posed a request for the '73 AIM and a kind member took some pictures, so you can see what pages I need, just from 75 instead...
Thanks Mike!
Thanks Mike!
Drat. My 75 AIM page is not particularly clear, but it looks like the single wire on the 75 harness plugs into the Ignition Fused slot at the top of the fuse panel; two-wire plug goes into Battery.
