looking to buy and want to know the best year between 68,69,70,and 71?
Old 11-07-2010, 09:23 PM
GD70
GD70's Avatar
70 had the lowest production run due to the GM strike in 69, making the 70 a bit more desirable for that reason. Seat design was revised for more head room. Less engine options than 69.
It comes down to taste as far as shark gills, egg crate, flared fenders etc... CONDITION, PRICE, COLOR, OPTIONS, MATCHING #'s will also play a big part in your decision and let's not forget Rust.
Take your time and you'll find a great Vette.
Glenn
Old 11-07-2010, 09:30 PM
demonx
demonx's Avatar
1970 = lowest production numbers
1970 = last year of the high horsepower 350ci engines
1970 = has a 454 which the 68 & 69 dont
1970 = egg crate grills (my prefered option)
1970 = modified rear guards to help defend stone chips etc
Old 11-07-2010, 10:02 PM
Raphiki
Support Corvetteforum!
Raphiki's Avatar
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
When you get into cars that are this old the individual car is what matters most. You have to check the basics on any of them and pick the best candidate for what you have to spend and what you want it to do. I have a '70 and love it but my '69 when it was new in '69 was in MUCH better shape.
What ever you decide drive the car, have it checked out thoroughly by someone you really knows old vettes and enjoy the hell out of it! Drive it like you stole it!
Old 11-07-2010, 11:14 PM
Brewcity
5th Gear
Brewcity's Avatar
WOW!!! What a respose! Thank you to you all!!
I will definitely take into consideration everything that you have told me.
Old 11-08-2010, 12:37 AM
7T1vette
7T1vette's Avatar
Received 2,715 Likes on 2,273 Posts
I haven't read the entire thread, so I may be duplicating ideas. Anyway...
'68-69s do not have extended flares behind each wheel well. This allows rocks/debris to be thrown on the lower panels of your car. Bad news. The '70 car has flares and has the most powerful engines of the C3 series cars. Compression ratios and power were reduced in '71 and later; but that means the '71 and later cars can run on today's gasoline...base engines run well on 87 octane and LT-1's/hi-perf engines will run on premium just fine. In '72 GM dropped the removable rear window.
Power cars: '68-70; low octane cars: '71 and later. Best car for the money: 1971's or 1972's.
Old 11-08-2010, 05:39 AM
SHOWME
SHOWME's Avatar
I don't see how you could go wrong with any of the steel bumpered vettes.Just find one YOU like that fits what you want.
Old 11-08-2010, 05:42 AM
hammadown
hammadown's Avatar
72's had the removable window..........73's and up did not
Hammadown
Old 11-08-2010, 09:05 AM
7T1vette
7T1vette's Avatar
thanks for the correction
Old 11-08-2010, 09:31 AM
Easy Mike
Easy Mike's Avatar
Received 1,470 Likes on 1,249 Posts
Cruise-In II Veteran
Here ya go. Purchase a copy, read about the various model years, and make your own decision.
Old 11-08-2010, 10:06 AM
highschool67
highschool67's Avatar
Originally Posted by PRNDL
So, if you start with 68s being either the best or the worst, 69 was basically a redo of 68 with some of the problems corrected (and some of the beauty diminished depending on your point of view)
I've owned a couple of 68's and love them. They were a little more expensive to restore. I have a 69 now and love it as well. I'm not sure about the quote from PRNDL? Sunken button on doors, ignition switch on dash, map pockets, and door panels with a grip handle and insert and optional chrome grill vents. Other than the paint colors that were changed for 69 ( I think Safari Yellow was one of my favorite vette colors) you'd be hard pressed to see the beauty diminished. They are roughly the same car visually.
Just my .02
Old 11-08-2010, 10:50 AM
TSAGG
TSAGG's Avatar
Not sure if true but was told by a local Corvette 'expert' when i was looking to buy that '68 was notorious for having rust issues. not sure exactly why, but was cautioned to really stay away from them unless they were thoroughly inspected. After that, i like '70 since it is a low production year (due to strike at plant) and has some big horserpower/compression ratios available.
Selling my '70 and want to get another '70, so i am biased i guess!
good luck with your search!
Old 11-08-2010, 11:25 AM
Corey_68
Corey_68's Avatar
Thanks, that's a new one I'll have to add to the "list".
Old 11-08-2010, 12:16 PM
  #33
Mashman
Mashman's Avatar
Originally Posted by Brewcity
I guess I left out the 72 due to horsepower drops for that year.
The 72 engines are pretty much the same as 71, they just switched from 'gross' to 'net' HP ratings.
Old 11-08-2010, 02:19 PM
  #34
7T1vette
7T1vette's Avatar
No reason for '68s to have any worse problems with rust than any other C3.
Old 11-08-2010, 09:03 PM
  #35
Tom73
Tom73's Avatar
That would apply to all C3's
Old 11-09-2010, 07:01 PM
  #36
Makonut
Makonut's Avatar
All the differences have basically been stated. To me the biggest difference is between the flared fenders of the 70,71, andnd 72 as opposed to the straight lines of the 68,69.
I think the big block 68,69 are terrific. They seem to be a little pricey though. I am not a fan of all the smog control on the 72. The 70 and 71 are very close.
Personally I am biased towards the 70.
Flared fenders,headlight washers and fiber optics plus the lowest production make it special
But it also depends on how factory correct of a car you want. For instance if you ever replace the carpet on a 70, it is near impossible to get the correct replacement. The early 70 also has a Briggs and Stratton alarm and tire lock. Very hard to find.
IOt is a matter of choice. All things consiered they are all great cars. Performance waise if that is your thing, then 68,69 is for you. Looks wise, I do prefer the 70-72 flared body. It just looks more aggressive to me.
Old 11-09-2010, 07:18 PM
  #37
thatcorvetteguy
thatcorvetteguy's Avatar
Did Chevrolet make Corvettes after 68???
To looking to buy and want to know the best year between 68,69,70,and 71?
Old 11-09-2010, 08:41 PM
  #38
Ironcross
Ironcross's Avatar
Nope, they went to Sting Rays and sacrificed some of the 68`s clean lines in doing so......
Old 11-09-2010, 10:18 PM
  #39
Frank.luvstingrays
Frank.luvstingrays's Avatar
I bought a 70 and just love it.........
Old 11-10-2010, 05:22 PM
  #40
mar
mar's Avatar
Look at a lot of cars - buy and absorb a lot of resource material on the marque - buy the car you like. Chances are - it won't be the one you are convinced about right now. Lot's of cars out there and pricing is generally pretty good now.
Hello to everyone,
I am looking to buy a C3, and would like to know from those of you whom have owned and driven these cars what the best year between 1968 and 1971 would be.
I am looking for one of these years, and need to know which one is the most dependable, has the fewest issues, and is the most street friendly for both city and highway.
I would be getting an automatic and most likely a big block.
ANY help would really be appreciate.
Thanks a lot!
Quick Reply: looking to buy and want to know the best year between 68,69,70,and 71?
