seatbelt reinforcement underbody 74
Dose any one know if they make the seatbelt reinforcement underbody
for a 74? can fine ones for 73,75 but no 74's. mine are shot to hell....
thanks...
thanks...
Try Paragon.
Seems they list 72-74 as the one. But I would call to confirm with them which one and which years.
https://www.paragoncorvette.com/p-35...forcement.aspx
Which seat belt reinforcements are you asking for. There are 3 different ones:
Shoulder belt in the rear wheel well- available zinc plated. This is rivited onto the fiberglass.
Lap belt -outboard side- these are welded onto the birdcage rocker channels, these are available but you have to lift the body to weld these on
Lap belt -inboard side, There is a horseshoe shape that is riveted in the driveshaft tunnel. You'd have to take the drive shaft out. This is not available from anyone. Used ones are $200 plus if you can even find one. These are zinc plated and are prone to rusting. The one bracket does both passenger and driver side.
These are for a 73, I would imagine a 74 is similar.
I replaced all of them on my 73. For the horse shoe one, I spend a lot of time repairing the rust on mine by welding in rusted areas and re plating. The nuts that hold the seat belt cable from this bracket to the #3 cross member are also not avialable from anyone.
Steve L
73 coupe since new
Steve L
73 coupe since new
Received 2,878 Likes
Hi Steve,
It's great to see you post. You have information people can use!!
Regards,
Alan
Regards,
Alan
Just going through this myself 72 and 73 are the same but not 74. I have what I thought was for a 73 but no way. If I could get a pic of a 74 one to see if this one matches I will make you a good price on it, it is in good shape.
If we are talking about the same piece, I will be removing mine from my 74 in a day or two and will snap some pics.
I think what Ozzy is talking about is the lap belt reinforcement plate that is screwed on through the the floorboard ( at least in my 73) underneath the center of the seat. The lap belt bolt goes through the floorboard into the plate.
No, To my knowledge, they do not make them and they are a one year only part. They are quite hard to get. The ones on my '74 were shot like yours...when I took the main bolt out, it crumpled to dust! I was lucky to get mine from a parted out 74 here (they are mint) on the forum. Try looking for parted out 74's here on the forum or around. Good luck.
If I see any for sale, i'll let you know but like I said, very rare it seems.
Will
Will
