Which 15 inch wheel/tire to fill fender flares
Old 05-05-2020, 09:18 AM
KWIL
KWIL's Avatar
St. Jude Donor '12-'13
Default Which 15 inch wheel/tire to fill fender flares
My 80 needs paint, and I've always loved the look of rear flares, so I am seriously considering cutting a couple of inches off the fenders, extending out a couple of inches, and glassing in between. But of course, my existing tires (255/60/15) will leave a huge gap. I have Jegs Centerline Auto Drag knockoffs, which I love, but they are 15x8 with 4.75 backspacing... so I'm looking at buying new rear wheels. Jegs no longer carries these, so I'll have to get authentic Autodrags. They offer 15x8.5 and 15x10, both with 3.31in backspacing.
I'd rather not have to buy a shorter leaf spring and offset TAs/ relocate e-brake, if possible.
With 3.31 offset, will the 15x8.5 wheel with 295/50/15 extend about 2 inches outside of the stock fenders, and fit inside without modification?
Or will the 15x10 wheel with 315/50/15/ 325/50/15 fit?
If I build my own flares, obviously I can adjust to the wheel/ tire combo but I want to be close to 2 inches outside stock, and fit inside without modification (I'll use wheel hub adapters if needed).
Unfortunately, I can't just order the wheels and tires and return them if they don't fit so I'm hoping to get it right the first time.
Anyone with a similar setup?
Old 05-05-2020, 12:05 PM
Dazaa Rafae Aman
Dazaa Rafae Aman's Avatar
Why not get some spacers made up to retain your current wheels?
Old 05-05-2020, 01:02 PM
KWIL
KWIL's Avatar
I have a 1/2 spacer/adapter on the rears already. I'd have to add an additional 2 inches of spacer to get it out far enough to fill the flares.
Old 05-06-2020, 01:04 AM
RBrid
RBrid's Avatar
Here's a reference point for you:
Front: MINILITE 9x15 ET-30, 265/50/15, 1.5" flares
Rear: MINILITE 10x15 ET-20, 295/50/15, 1.5" flares
https://www.corvetteforum.com/forums...post1599974485
Hope this helps
Old 05-06-2020, 08:34 AM
KWIL
KWIL's Avatar
Hope this helps
Looks great. Maybe I missed it but what's the backspacing on the rear wheels? And did you have to relocate the e-brake, offset TA, shorten spring?
And what flares are those? The only similar flares I've seen are 2 inches, not 1.5.
Old 05-06-2020, 10:32 AM
RBrid
RBrid's Avatar
ET-30 for the front means 3.82" BS, and ET-20 for the rear means 4.71" BS (http://www.gtsparkplugs.com/Offset-to-Backspace.html).
relocate the e-brake: No
offset TA: Yes
shorten spring: No, SharkBite system
flares: They are the known 2" flares but in practice they are only about 1.5" more than my OEM 1977 panels
Old 05-06-2020, 05:29 PM
KWIL
KWIL's Avatar
offset TA: Yes
If my understanding of wheel backspacing is correct, then compared to your 295/50/15 w/ 4.71 BS, if I go with 15x10 centerlines with 3.31 BS, I'll be about 1.4 inches further out than you, which would mean I'd be looking at about a 3 inch flare to cover 295s, and about a 4 inch flare if I can find 315/50/15s. Does this sound right?
Old 05-06-2020, 05:54 PM
doorgunner
Nam Labrat
Support Corvetteforum!
doorgunner's Avatar
Received 4,179 Likes on 2,739 Posts
Buy the rims and tires......then cut out the openings/install flares to fit the new. Wheels!
Old 05-06-2020, 07:46 PM
RBrid
RBrid's Avatar
"I'll be about 1.4 inches further out than you": Correct.
"which would mean I'd be looking at about a 3 inch flare to cover 295s": Correct.
"and about a 4 inch flare if I can find 315/50/15s": I don't think so. First, would 315/50/15s safely fit on a 15x10 rim? Assuming the answer is yes, a 315 tire would only stick out about 1/3" more than a 295. So your flare would have to be about 3 1/3".
Hope this makes sense. Good luck finding 315/50/15s by the way. Let us know if you do.
KWIL (05-06-2020)
Old 05-07-2020, 02:49 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
This sounds pretty sensible! Then you get a perfect tuck/fit and know how it will come out.
Old 05-07-2020, 09:08 AM
KWIL
KWIL's Avatar
This is definitely the plan. My main concern though was whether or not those combos would fit on the inside without e-brake relocation/ springs/ TA mods. From what I gather, the 15x8.5 with 3.31 BS with 295/50/15 should not require inside mods. Still not sure about the 15x10 with 315 or 325/50/15s.
To Which 15 inch wheel/tire to fill fender flares
Quick Reply: Which 15 inch wheel/tire to fill fender flares
