shell swap
The last 18"-24" has to be changed to the 72 frame section, you might have to re-work the front as well
Thanks guys, the cosmetic changes I can probably get round, as long as the main mounting bolts are the same I'll go ahead with it. Anyone know if they're different? Thanks
Do you have an early frame you can cut up?
Also, check this out...69 front and rear on an 82...awesome work!
http://www.digitalcorvettes.com/foru...d.php?t=114209
