Oh dear that does not sound good
can anyone shed some light on the sound in the video clip?
http://s990.photobucket.com/albums/a...t=MVI_0037.mp4
While tooling around checking my ignition timing with my new distributor I started hearing this terrifying sound. Anyone have any clue as to what it could be?
Received 4,565 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Hammerhead may be right on the money. Also your timing sounds way too retarded. Good luck
Does the fan wobble when you grab it at opposite ends & pull back & forth? If so, replace the water pump, the bearings are shot.
Alternator usually has a high pitch whine when the bearings go.
Chasin' that noise
Another homemade tool that can be used to chase down a noise is just a piece of a broom stick. I've used it many times on cars and RVs.
Good luck
GaryC - '78PC - Franklin, IN
Good luck
I am no expert, and I did not stay at a holiday inn last night, but sounds like water pump going out to me. I went through that back in May of this year.
Mike.
Mike.
Harbor freight stethoscope for under ten bucks. Sears is cheap,too. helped me find a bad clutch throwout bearing on a mustang, everybody that listened to it thought it was a idler pulley. Just used the metal tip for the scope and slowly move it around. Louder-closer. Valves sound really cool, too! (okay-way too much free time on my hands..)
Noticed you have got new valve covers on, it would pay to check that there is no rubbing inside by a rocker happening, some of the clearances are tight. As some have said, use a short length of garden hose to listen for the source, move it around until it gets loudest.
