Crate engine delivery info
As I understand it, it comes on a skid and you get delivered off a "lift gate." I gotta get this into my backyard. Do you get any help from the truck driver? I mean, does he have a pallet jack? Way I figure it, I'll need a couple sheets of 3/4" plywood and a pallet jack. I assume they can drop off in your driveway? thanks
I have had to pick them up off the street.......I just used my engine puller....it has wheels.....it's a little of a pia because it swing as you pull it but I just keep the engine low/close to the ground.....no problem.
I guess you are using the ply as a base over the dirt? the wells on my engine puller would need the ply to roll over grass. Weather he will go over your ply with his jack is some will some won't......if no is the answer, you need a back up plan like drop it in your garage and deal with it later. Sometimes a $20 cash can change his mind.
Hope this helps
Hope this helps
Hope this helps
thanks
How about a steel flatbed or garden wagon with inflatable tires you can buy at Menard's for $100 to placed it on. Then you could pull it across the lawn. It might be a good idea to have someone handy to help stabilize it. Then you still have the wagon for gardening.
A pallet jack is going to be hard to get across dirt and grass.
it was a new zz4 from g.m through summitt .
be extra careful if you find extra parts mine came with two water pumps . guess why .
the one on the engine had the pully holes stripped .
more of that good old goverment motors uaw crapmanship
typical white person
Gary
My delivery we on the street in front of my house. Driver said insurance would not let him help me in any way. So, I used a sheet of plywood and a hand truck from Lowe's. Delivery weight was 501 pounds and I had to move it about 175 feet!
I just kept moving the sheet of plywood.
Thanks for the info guys on the pallet jack probably being not a good idea. I will check out the wagon with wheels idea from Loews or maybe Home Depot since I don't have a Loews real close by. I can't believe you moved a motor on a hand truck .
Thanks, Fred
Thanks, Fred
I have used an engine hoist, one time they had a forklift on the truck and put it where I wanted, or you can beef up a furniture dolly. There are also industrial equipment dollys that you can rent. Good luck and be safe!
I have a couple of those mover's dollies. I use them to store my JD snow blower and dozer blade in my shop so I can move them around. Never tried moving a V8 engine with one but I don't see why not, as long as it's a hard smooth surface.
When I purchased my 383 short block, it was shipped in a 55 gal drum wrapped in carpet padding and carpet. I don't know if a complete engine could be shipped this way, but packaged this way it was easy on to my pickup at the freight terminal using a barrel jack, and easy off at my house with the help of one other guy.
Easy to tell if there was any shipping damage when taking delivery. No holes in the drum from the forklifts, then the contents should be ok.
Dropped the drum on to the lawn, with some padding, rolled the drum into the garage, removed the drum lid and slid the short block out.
Hey , I got one of those "furniture" dollies. On another note, I went to the tool rental place yesterday and the guy there suggested ( as said by Richard above) a hand truck. He's got one there that has a 1000 lb capacity and a strap. Looks like one way or the other, I'm now set. Thanks for all the info guys. .
ps. Richard, I sent you a PM
Location: Where it's always hot as Hell-South Louisiana.
1 Post
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
if the delivery address has already been submitted, then I'm too late with this suggestion:
Find your nearest freight dealer, i.e.; Lumber yard, air conditioning supply house, brick yard, etc , ask if they will take delivery. Being a friend of one of these is a major plus. They will usually do it for free and load it in your truck . Did this on a few crates my ownself.
If you get it delivered in yor front yard, get help. My wife is not considered "help" for this kind of occasion. ask me why.
2nd - I think after I get it strapped on, it would be easy to get my assistant (my wife ), to help me push it into the backyard - after laying down a couple sheets of plywood. If that doesn't work, I have a fat *ss neighbor that could provide some more umph.
