Wood Trim Issues
Old 07-13-2010, 11:29 AM
davisej
3rd Gear
davisej's Avatar
Default Wood Trim Issues
I just had the interior completed on my '74. While it looks great - I'm having issues with the "wood" trim on the door. I've tried a few different adhesives - but as soon as my vette sits in the heat for a few hours the trim separates from the door. Any advice would be greatly appreciated.
Old 07-13-2010, 11:46 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Had you used Armor-All on the area under that panel? That stuff is hard to get rid of and will prevent adhesive from adhering well. You may have to devise some sort of mechanical retainer system for that panel...something like using epoxy glue to add some small plates with pins on them to the back-side of that panel, then push the pins through the door panel and bend them over (similar to the trim piece on the lower section of the early '70s door panels).
Quick Reply: Wood Trim Issues
