Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-25-2010, 04:06 PM   #1
TERRY CLARK
CF Senior Member
TERRY CLARK's Avatar
Default Corvette weight !
Anybody know the weight of the different years.............Which is the heaviest & the lightest? I have a '73 coupe, 350/400 with hookers without a spare tire, it's heavier than I thought !
TERRY CLARK is offline   Reply With Quote
Old 06-25-2010, 06:07 PM   #2
TheSkunkWorks
CF Senior Member
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Not me, but I'd almost be willing to bet the ZR1's were the lightest C3's ever.
TheSkunkWorks is offline   Reply With Quote
Old 06-25-2010, 07:16 PM   #3
79L48
CF Senior Member
79L48's Avatar
In terms of broad generalities, the higher the year, the higher the weight, topping out in '79. In '80, the aluminum batwing rear end, thinner glass and a magnesium front crossmember made the cars lighter. I don't know whether they were lighter relative to the early C3s, but they were about 150 lbs lighter than a comparable '79.
79L48 is offline   Reply With Quote
Old 06-25-2010, 07:36 PM   #4
DZRick
CF Senior Member
DZRick's Avatar
This site has all the C3 specs listed the weights are listed under the identification header.
The link starts with the '68 at the bottom you can pick what year you want to check.
http://www.100megsfree4.com/corvette/1960/vet68.htm
DZRick is offline   Reply With Quote
Old 06-25-2010, 07:36 PM   #5
thegavel
CF Senior Member
thegavel's Avatar
Gooday,
My 74 coupe was weighed when it was registered-1550 kg = 3417lb.
People are amazed when I tell'em that it weighs the same as one of our Aussie family cars !!!
Cheers
thegavel is offline   Reply With Quote
Old 06-25-2010, 08:06 PM   #6
69427
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
Quote:
I'm not up to speed on that crossmember item. Can you expound more on that?
69427 is offline   Reply With Quote
Old 06-25-2010, 08:09 PM   #7
Attfay Elleybay
CF Senior Member
Attfay Elleybay's Avatar
http://forums.corvetteforum.com/c3-t...0-gallons.html
Attfay Elleybay is offline   Reply With Quote
Old 06-28-2010, 09:57 AM   #8
TERRY CLARK
CF Senior Member
Thanx Man !
Old 06-28-2010, 10:55 AM   #9
PRNDL
CF Senile Member
Support Corvetteforum!
PRNDL's Avatar
Mark Jackson @TraderJaxon
Send a message via AIM to PRNDL
68 bigblock..... with me in it.. ( 190??)
Click the image to open in full size.
PRNDL is offline   Reply With Quote
Old 06-28-2010, 11:22 AM   #10
Tom73
CF Senior Member
Tom73's Avatar
Quote:
Check the '73 Spot, the weights for the '73 are there in the Tech Info section, and the options.
__________________
Tom73
Need info on the '73 Vette?
Tom73 is offline   Reply With Quote
Old 06-28-2010, 05:35 PM   #11
68/70Vette
CF Senior Member
The shipping weights shown in the reference link are probably for SB cars without air conditioning. There's been a lot of postings listing the weight of the BB as compared to a SB. (about 200 pounds?). Also, Someone said that AC added 150 pounds to a car. Don't know if that's true.
My 68 SB probably weights about 2800 pounds based on the shipping weight. All aluminum heads, intake manifold, water pump, radiator, brake calipers, and wheels. Composite spring and spare tire/tub removed.
68/70Vette is offline   Reply With Quote
Old 06-28-2010, 05:44 PM   #12
Tom73
CF Senior Member
Tom73's Avatar
In '73 the BB added 211 lbs, A/C added 90 lbs with the BB, 80 with the SB with auto, and 95 with SB and manual trans. Power Windows add 7 lbs and Power Brakes added 10 lbs.
The 73 started at 3326 shipping weight for the coupe and 3333 for the convertible.
All per the '73 Spot.
__________________
Tom73
Old 06-28-2010, 06:05 PM   #13
Kadorja
CF Senior Member
Kadorja's Avatar
No one believes me when I say my 80 weighs about the same as my dads 2008 Vette. My shipping weight is 3206 and my dads curb weight is 3217.
As of right now my A/C is in my garage and I dont have a passenger seat.... so all I need is another 500hp or so to keep up with him. Maybe ill go with an all aluminum LS3 and a procharger.....
Kadorja is offline   Reply With Quote
Old 06-29-2010, 12:26 AM   #14
LS4 PILOT
CF Senior Member
LS4 PILOT's Avatar
I'll bet my car is near the top , if not FAT ALBERT of the whole C3 line...
It could pass for a new born TIGER TANK
LS4 PILOT is offline   Reply With Quote
Old 06-29-2010, 08:16 AM   #15
Vettekid1992
CF Senior Member
Vettekid1992's Avatar
most c3's r just around 3500lbs but i stripped my car down and its now 3000lbs with me in it so its like 2850 with a full tank of gas
Vettekid1992 is offline   Reply With Quote
Old 06-29-2010, 12:46 PM   #16
LS4 PILOT
CF Senior Member
LS4 PILOT's Avatar
Actually my car is a bit over 2 tons ......
With my mamma-in-law on board.....
Old 06-29-2010, 03:51 PM   #17
68/70Vette
CF Senior Member
Quote:
These weights, in the low 3000 lb range, are a lot lighter than some other cars. Look at the Mercedes Benz two seaters, many are right at 4000 lbs. Also, the BMW models are right up there. The new Camaro is about 4000 lbs and the Ford Mustang is slightly less.
Reload this Page Corvette weight !
Tags
1968, c3, corvette, corvetteweight, heaviest, vette, weight, weights, year
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
