Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-04-2010, 04:54 PM   #1
udornf4
CF Senior Member
udornf4's Avatar
Default Towing with a Tow Dolly???
Anyone have any experience towing a C3 (auto) with a Tow Dolly?
thanks!
udornf4 is offline   Reply With Quote
Old 04-04-2010, 05:03 PM   #2
TheSkunkWorks
CF Senior Member
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Not specifically with a C3, but I'd either pick it up by the rear or remove the driveshaft. Without the engine running there's a risk there won't be enough circulation in the trans to guarantee you won't burn up something in neutral. Learned from having seen this happen more than once to others towing vehicles behind their motorcoaches.
TheSkunkWorks is offline   Reply With Quote
Old 04-04-2010, 08:56 PM   #3
stpman
CF Senior Member
stpman's Avatar
Haven't towed a C3 with one but the 2 times I did tow with one told me to never do it again
stpman is offline   Reply With Quote
Old 04-04-2010, 10:21 PM   #4
Bugman Jeff
CF Senior Member
If you don't disconnect the driveshaft, you will almost certainly burn up the trans. The pump is driven by the engine, so with the engine off there is no trans fluid circulation.
Bugman Jeff is offline   Reply With Quote
Old 04-04-2010, 11:00 PM   #5
jordan89
CF Senior Member
jordan89's Avatar
Why don't you just rent a U-haul trailer for $50. You won't have to worry about anything.
jordan89 is offline   Reply With Quote
Old 04-05-2010, 12:41 AM   #6
Dantana
CF Senior Member
Dantana's Avatar
I did it about 3 years ago... and now I see maybe i shouldn't have...
I took mine 15 miles on stop and go roads (very slowly) from the place where the brake cliper locked down on the disk to home. I put the front on the dolly and did not disconnect the drive shaft. I hate my auto trans anyway, but it seems to be working as well as it was before I towed it.
Dantana is offline   Reply With Quote
Old 04-05-2010, 11:25 AM   #7
mikejpss
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Location: Where it's always hot as Hell-South Louisiana.
Quote:
AND the U haul trailers work really well for the C3's. Just make sure you tell them what you are towing so they will give you the correct trailer.
mikejpss is offline   Reply With Quote
Old 04-05-2010, 12:26 PM   #8
TopGunn
CF Senior Member
TopGunn's Avatar
Quote:
I agree also, in fact I'm towing mine Friday a couple hundred miles.
These cars are pretty heavy, mine is 3690# added to the trailer weight of 2200# puts it over 5000#. A class III hitch is rated for 5000# and allot of pickups aren't rated for that weight (even though they'll probably pull it OK)
I believe U Haul does have an aluminium trailer that weighs less but i don't know how much.
TopGunn is offline   Reply With Quote
Old 04-06-2010, 03:53 PM   #9
builder
CF Senior Member
I wouldn't go too far with a tow dolly unless I had a large tow vehicle. The tow dolly with a car on it behind a pickup can push the rear of the tow vehicle sideways on a corner and loss of control is easy. I would recommend using a trailer with brakes on all wheels.
builder is offline   Reply With Quote
Old 04-07-2010, 12:38 AM   #10
croaker
CF Senior Member
croaker's Avatar
Get a uhaul car trailer way better than a dolly about a hundred bucks a day
croaker is offline   Reply With Quote
Old 04-07-2010, 07:38 AM   #11
jeffp1167
CF Senior Member
jeffp1167's Avatar
I once towed my 82 vette on a dolly behind my 84 trans am for about 60 miles. No side effects from nothing being disconnected and the car towed great on the dolly. If longer then a 100 miles, then I would take the driveshaft out
jeffp1167 is offline   Reply With Quote
Old 04-07-2010, 08:16 AM   #12
OzzyC4
CF Senior Member
OzzyC4's Avatar
U-Haul wont rent you a trailer if your tow vehicle is not within their requirements for what you are going to tow.
Click the image to open in full size.
If the 4 Runner had been 2 wheel drive it would not have qualified. (tow vehicle weight)
OzzyC4 is offline   Reply With Quote
Old 04-07-2010, 02:28 PM   #13
builder
CF Senior Member
I just wouldn't recommend for anyone to use a tow dolly unless they have a "heavy" tow vehicle. I also wouldn't recommend towing a corvette with one.
Also, In my state, the tow dolly doesn't need to be licensed or insured, but the towed vehicle has to be insured and licensed if the wheels are on the ground. Might want to check on that too if you decide to use a tow dolly.
Old 04-07-2010, 04:33 PM   #14
Fishndude
CF Senior Member
Fishndude's Avatar
If you tow with a dolly, from the front, dont even attempt it unless your steering locks, otherwise your wheels will try to turn when going around corners and the tires wont straighten back out again after you come out of the corner... Trust me I know, we had to pull over about 8 times and straighten the front tires back out on the way to the muffler shop..
FD
Fishndude is offline   Reply With Quote
Old 04-08-2010, 08:54 AM   #15
J.K. Cooley
CF Senior Member
J.K. Cooley's Avatar
I would only use a tow dolly if all other options were exhausted.....As mentioned by others -- Tie-off steering to seat frame, remove driveshaft .......
__________________
1965 Roadster
Super Chevy Show Winner
2006 2007 2008
1972 Coupe
Street Driven Modified Work in Progress
http://www.cooley-enterprises.com
J.K. Cooley is offline   Reply With Quote
Old 04-08-2010, 09:25 AM   #16
builder
CF Senior Member
Although most agree that a tow dolly is just "wrong", I would have to disagree with the tying off or locking the steering wheel. Although the wheel plates swivel on the dolly (mine does), the wheels should be free to turn too. I would suggest that the wheel harnesses are not tight enough if the wheels turn in them. You want the towed vehicle to follow and trail. If the steering is locked, you could tweek the tow dolly, but more likely put a lot of extra force on your steering and suspension system and possibly tweeking it. I usually get the wheel harnesses as tight as I can by hand, and then give it another shot with my foot. Make sure the tires are nice and hard on the towed vehicle too. Adding a little air to the harnessed wheels can also help tighten up the wheel harness.
I always;
1. take a battery powered air compressor and inflate the tires to their max psi.
2. tighten the wheel harnesses with my foot.
3. check harnesses after 5-10 miles.
4. use safety chains (they saved me once).
5. leave the steering unlocked.
6. make wide turns.
7. never back the dolly up with a vehicle on it.
8. always use a heavy towing vehicle.
9. never tow a Corvette with a tow dolly.
Old 04-08-2010, 10:38 AM   #17
Fishndude
CF Senior Member
Fishndude's Avatar
Quote:
We tried it with the straps extremely tight too and the problem was even worse. When we turned a corner, the tires would bind and turn in the straps, know matter how tight we had them and then they would stay bound after we straightened them back out again, which then caused the the car to track sideways.. We also tried the swivels in the locked and unlocked position and still had the same problem.. BTW, we also took 2 lane wide corners and it still bound the tires. I found a post on a RV froum where a guy had one strap bust due to the excessive pressure when his steering wasnt locked. I also couldnt believe the pressure it was applying and how it was still turning in the straps..
Here is a tow dolly manual link, which clearly states the steering should be locked. Here is a quote from the manual
Place the ignition switch in the steering wheel to the locked position and make sure that the front wheels
are pointing straight ahead. Assure that steering wheel is locked and will not turn. (Parking brake is to be
released after tie down procedure is completed.)
On vehicles not equipped with a steering wheel lock mechanism is imperative that the steering wheel be
immobilized by tying it to the seat frame or other suitable point with a ratchet strap or other device
FD
Old 04-08-2010, 01:01 PM   #18
builder
CF Senior Member
I stand corrected. I have not had much problems although I only use a tow dolly within 15 miles, but......refer to item #9 on my list.
That's not in the manual.
Old 04-08-2010, 01:10 PM   #19
Fishndude
CF Senior Member
Fishndude's Avatar
That is the best point and I totally agree.. I will never do it again, thats for sure
FD
Old 04-08-2010, 02:01 PM   #20
SharkintheWoods
CF Senior Member
SharkintheWoods's Avatar
Send a message via AIM to SharkintheWoods
I agree with don't tow it with a dolly. Years back I towed my 80 from Houston to Atlanta on a dolly since the vehicle I had at the time wasn't approved by uhaul for a trailer. Once the car was on the dolly it towed OK unless of course you needed to back up in any form or fashion. The huge problem I had with it is I had to pick the car up and slide the dolly under it. The nose is too long and low to drive the car onto the dolly. It was about as much fun getting it back off the dolly and I yanked the clip that holds the air dam in place off in the process. I would not recommend it as a whole for sure.
SharkintheWoods is offline   Reply With Quote
Reload this Page Towing with a Tow Dolly???
Tags
atlanta, c3, c4, c7, california, car, corvette, dolleys, dolly, fbody, licensed, required, rv, tow, towed, towing, trailing, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
