Vacuum tank for head lights
Old 03-16-2010, 08:15 PM
TJ1980vette
TJ1980vette's Avatar
Default Vacuum tank for head lights
ok so I have a problem with my head lights going up and down so I started checking lines and found that the coffee can in the font was leaking air. In the process of taking it out the adapter piece broke off and i was wondering if i really need to have this or if I can bypass this I have looked online for a new one and ecklers has a part number but they say it's discontinued.
Old 03-16-2010, 08:37 PM
...Roger...
...Roger...'s Avatar
The headlights will go up and down without the coffee can as long as the engine is running and you connect all 3 hoses together.
Old 03-16-2010, 10:54 PM
Fonz69
Fonz69's Avatar
Or you can get a aftermarket type from summit like I did on my 69
[IMG][/IMG]
Old 03-16-2010, 11:07 PM
dburgjohn
dburgjohn's Avatar
Default Jegs has them
Jegs carries tanks in plan or fancy. Plain tank is only $29
http://www.jegs.com/i/JEGS/555/63010/10002/-1
To Vacuum tank for head lights
Quick Reply: Vacuum tank for head lights
