fan clutch mount kits reversed from older ones
Old 07-08-2017, 01:41 PM
Babypig
Babypig's Avatar
Default fan clutch mount kits reversed from older ones
What is going on with thec3 fan clutch to water pump stud kits? A new one is opposite what it used to be. WTF. If you seat the fine threads on the none threaded band there is no room for nut and lock washer. Now there is alot of fine thread stud sticking out the motor side of the water pump flange. What am i missing here?? Anybody?
Old 07-08-2017, 02:14 PM
MelWff
MelWff's Avatar
Received 1,817 Likes on 1,606 Posts
install bolts same thread but a little longer than the studs
Quick Reply: fan clutch mount kits reversed from older ones
