Custom wrap paint test
Old 07-07-2017, 08:24 AM
lakerider57
lakerider57's Avatar
Default Custom wrap paint test
Since it's going to be some time before I'll be actually painting my car since I'm doing a body-off restoration, I was wondering if a spray-on custom wrap would look any good. So I saw the 11oz. cans on sale for $4.99 so I bought some to try. I only bought one can of each color and probably needed 1/2 can more for the hood but still a decent test.
The product I used:
Here is original hood which I only wiped down, no sanding, which it really needs, but hey, this is a test:
Here is the same hood done in Performance Red:
There is glare on the hood from overhead lights, but this is from one can and I think it would take approx. 10 cans to do the whole car based upon this area being the largest (should be about $50). When I'm ready to really paint, I can peel it off and sand, and paint.
Do you like or not ?
Richard
Old 07-07-2017, 08:32 AM
The13Bats
The13Bats's Avatar
Is this the same as plastic dip?
I like it for some things, my car might get some on it...
Old 07-07-2017, 08:38 AM
lakerider57
I have never used plasti-dip, but this stuff sprays on very nice and you can buy a gloss also for a top coat. My wife says she would be embarrassed to ride in the car the way it is but she said she liked this stuff.
Richard
Old 07-07-2017, 08:44 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by lakerider57
...Do you like or not?...
I don't like it, but that means diddly-squat; it's not my car.
Why not wait for paint? You imply the body is off the frame. If that's the case, why go to the expense of the wrap if the car isn't going to be going anywhere soon?
Old 07-07-2017, 08:48 AM
lakerider57
I was thinking that I could get the car on the road sooner once the top and chassis get mated up and then work on sanding/painting when I feel like it. Just an idea...
Richard
Old 07-07-2017, 10:05 AM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
just seems like your gonna do the same work twice to me.
not a fan on the cheap spray on plasitc, but it is your car.
for nearly the same amount of work you could do it once and be done.
Old 07-07-2017, 07:32 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi l,
Will you put 5" diameter exhaust extensions on it too?
Regards,
Alan
Corey_68 (07-07-2017)
Old 07-07-2017, 08:42 PM
427SIXPACK
427SIXPACK's Avatar
not too bad for the time being / better then no color at all or sand & scuff marks or multiple touch up colors / seen a lot worse / way, way worse !
Old 07-08-2017, 12:36 AM
The13Bats
The13Bats's Avatar
Plastic dip, spray plastic and even wraps simply are not replacements for a high end, costly paint job, i doubt they ever will be,
But i dont care at all, i might use them on my 69, if you dont like it thats a you problem,
Some guys like to think outside a box and try new things, work on and drive their cars, other guys want to just look at their car and tell others how they should build,
both are car enthusiasts too bad one side feels they have to poke at the other...sad.
Old 07-08-2017, 07:51 AM
The Punisher
The Punisher's Avatar
Looking at your test hood I think if you would have sanded it and maybe used an additional can it would look even better. Can the duplicate-color be bought in a quart and sprayed with a gun? I have seen some really great plasti-dip paint jobs when sprayed from a gun.
chazde3 (07-08-2017)
Old 07-08-2017, 07:59 AM
car junkie
car junkie's Avatar
Consider a scuff and tinted to your liking epoxy primer paint job. You could probably do the whole car for about $150 and it would look a lot better than that.
Old 07-08-2017, 10:33 AM
C3 4ME
C3 4ME's Avatar
I've been considering doing this to my old C10 pickup. It's an ugly rusty truck and not worth the effort to put a nice paint job on it, so I think this might be a cheap option to make the truck look a little better.
Old 07-08-2017, 10:38 AM
WideVette
WideVette's Avatar
$150 (+/-) gun, some practice, several coats, glossifer, and the finish can look killer and be removed later. Spray can for trim, emblems, etc.
Old 07-08-2017, 02:23 PM
Cool95vette
Cool95vette's Avatar
I did mine last year to make it presentable until it gets painted. It's holding up pretty good.
Old 07-08-2017, 05:29 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
If you want to do that temporarily, I'd say "go for it". But, my suggestion is that you go with a satin black paint that would look more like primer. That stuff in a regular color looks pretty 'cheesy' to me. For a primer car, it wouldn't look odd.
To Custom wrap paint test
Quick Reply: Custom wrap paint test
