74 coupe question
74 coupe question
I recently purchased a 74 coupe and am redoing the interior which I have started to remove. My question is how do I remove the e-brake cover from the car,the front console and guage cluster have been removed.
Good to get an Assembly Instruction Manual (AIM)
I believe you have a screw maybe a 3/8" socket head that you have to undo from inside the compartment behind the seats. Located in the center. Also a couple of screws, one on each side which you likely found already.
Hope this helps.
Good to get an AIM which shows all of the screws and parts.
Hope this helps.
Hope this helps.
The one in the back of the console is easy to get out and a pain to get back in. At least it was for me and for some reason, I had to install and remove that dude more than once for some reason.
Received 1,470 Likes
Cruise-In II Veteran
The '74 AIM will help. It shows the installation of the bolt you're looking for.
Now thats just funny. me too. wasn't funny then, though. just brought back an old memory and had to laugh.
compartment.
