Picture of how horizontal channel attaches to side window glass??
My hardware, attaching the horizontal channel to the window glass, is not original. I have scoured the AIM for a picture of correct sequence of plastic bushings, rubber washers, nuts, etc and havent found anything.
Does someone have a good photo of how it all correctly goes together? I have a kit of new plastic components, but it didnt come with any instructions.
Both windows on my car were assembled differently (PO in the past I would have to assume), otherwise I would use a "correct" one as an example for reassembly.
Thanks,
Rob
Thanks,
Rob
I think Alan has some pics of his setup
found some.........
you should take a look through my photobucket there should be plenty of pics that may help you along the way
http://smg.photobucket.com/albums/v480/hammadown/
Hammadown
found some.........
Hammadown
Received 2,878 Likes
Hi Rob,
Either I don't have a picture or I can't find it.
This page is from the 71 AIM. I think it shows clearly enough what fasteners go where. If you have a question someone may be able to answer.
Regards,
Alan
PS: I see now that HD has posted some pictures. I think the AIM calls out what is a bolt,washer, bushing and nut.
Regards,
Alan
.....you should take a look through my photobucket there should be plenty of pics that may help you along the way
Hammadown
Hammadown
Exactly what I was looking for!
Thanks,
Rob
Hi Rob,
Regards,
Alan
Regards,
Alan
Thanks for the AIM page! I couldnt find it in my AIM because I had removed it for the impending "window job". I didnt notice the page #'s skipped a page!!
Now to go hunt down the missing page! I KNEW I had seen it somewhere in the AIM previously...
Its a Bitch getting old!!!
Thank you sir!
Rob
Hi Rob,
I'm VERY old these days.
Note that the track varies SLIGHTLY from end to end. The 'longer' flat area goes on the rear of the window. I'm not sure why? Maybe so you can get the roller/slide on and off the track with the end mounting nut in place? There was a question about this a couple of weeks ago.
Regards,
Alan
Regards,
Alan
