The 80 c3 that I have traded for and going to rebuild had no key for the ignition switch you just turned the switch itself to start the car, I bought a new switch to install with keys, everything went perfect installing but the switch when installed likes about 1/8 of inch turning back far enough to release the key, in other words the car starts, turns off everything except you cannot remove the key. Any idea's I even thought it might be a bad switch so went and got another one same thing. Out of idea's I have taken the switch in and out so many times I can almost whistle and it reinstalls.
You may have to adjust the switch on the lower part of the column under the dash. There are 2 small screws to loosen then the switch has elongated holes for adjustment.
I agree you need to adjust the actual switch, the lock cylinder is attached to a rod,
down the top of the column and connects to the actual switch,
it is held in place by 2 screws and the mounting holes are slotted to allow
for proper adjustment.
good luck ... 69VETTE
I dont want to insinuate that you are a "DUH" but are you tripping the lever that allows you to move the key that extra little dinch to remove it ? Peace,,,Moosie
__________________
'80 L-82, Presently in the process of taking the '80 apart cause it's a rust bucket, And putting the drivetrain and interior into an 82 that I bought. With a changeover to a 4 speed while I'm at it. Other interests My son and daughter. Our '40 Ford Deluxe tudor sedan (stock for now) and our favorite,,,, ole Blackie, our '78 Harley Davidson Low Rider (FXS), the "REAL" freedom machine!
Ever wonder what the speed of lightning would be if it didn't
zigzag?
