your not forgoten
Old 11-13-2009, 10:43 AM
tomgallucci57
tomgallucci57's Avatar
Default your not forgoten
to all how have helped me with my wiper motors terminal, i want to say thank you very much.as is im still awaiting willcoxs reply to,,, my 68 service manual shows a terminalboard with a cylindrical type spring,possibly a resister, intergrated into the bottom end of it. do all 68 s have the same ter. board. because a forum friend has two wires coming out of his wiper motor at the plastic gromet on the side of the motor, while my wip. motor has three wires, possibly making the terminal board a different version. so is there a difference between early and later 68 wiper motors....... again i just wanted to say hello, and thanks,
p.s. for those who havent been following this thread, my 3 prong terminal board was missing off my wiper motor when i recieved the car,and id like to locate the proper one........chow.... tom
Old 11-14-2009, 07:11 AM
Droptop-Rob
Droptop-Rob's Avatar
Tom,
All 68's had the 20 ohm resister, it is for the wiper motor to achive low speed. I is common for these motors to be hacked on over the years...
Good luck
Old 11-14-2009, 07:00 PM
DZRick
DZRick's Avatar
This is on an original '68.
I'll have to remove the wiper motor from my car someday to see if in fact there is supposed to be a resistor.
In the picture above you can see that the yellow wire lands on the same terminal as the black. I don't think it would be very difficult to add the extra wire using a later terminal board.
This is most likely a '69 and was on my brothers car.
Old 11-14-2009, 07:20 PM
hammadown
hammadown's Avatar
[/QUOTE]
Sorry...but I have to mention that you have a dead fly on the threaded bar in your switch
Hammadown
Old 11-14-2009, 07:32 PM
DZRick
DZRick's Avatar
Hammadown [/QUOTE]
After posting the picture I saw the wing. Can't keep them out of the garage, they like to move in for the winter.
Old 11-14-2009, 07:57 PM
PRNDL
PRNDL's Avatar
There's a bug in my switch!
Old 11-14-2009, 08:31 PM
nutsy
nutsy's Avatar
Hammadown
After posting the picture I saw the wing. Can't keep them out of the garage, they like to move in for the winter.[/QUOTE]
lmao
Old 11-14-2009, 09:49 PM
Droptop-Rob
Man, it looks like a fly is on your resister. It is hard tell in the pic it does look like a threaded rod, however the resister looks similar from a distanceand is in that exact location. It is a porclin rod that is wire wrapped creating the resister. put a meter on it if is not attached to anything it should be 20 ohm. In the system the black wire is removed via the switch to place the motor in high speed.
Old 11-14-2009, 10:22 PM
DZRick
DZRick's Avatar
That is the resistor Rob. The '68 picture doesn't have one but I'm not sure whether it should have one or not.
The rest of you guys are killing me, you have no idea how difficult is is to get a fly to hold a pose.
Old 11-15-2009, 12:33 PM
tomgallucci57
in the mean time,im going to go to junk yard and remove a terminal board from a 71 grand prix that i saw the other day. i just want to look at it.who knows, it might work. again, many buchels full of thanks for all assistance thus far. the 68 board is in question as to the resister being there or not. talk to you guys later, tom
p.s. hate to say it, but isnt that a no fly zone.
Old 11-16-2009, 09:17 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Boy,
What I wouldn't give to be a fly on the .... Resistor.... Just isn't working.
The resistor was used on the terminal block for 68-72. I don't have the value of it, but I can get it tomorrow for you guys if needed. You have to have this on the terminal connection.
I'm not sure what other applications used this terminal, but it appears to be a pretty common one.
I pulled some old pictures today of the wiper motor we used when we did the write up... Please keep in mind that it's pretty hard for me to keep all this stuff stored away in my decrepit brain. This motor is an original 68 motor and it has the resistor on it.
Willcox Inc.
Old 11-16-2009, 09:21 PM
0Willcox Corvette
Former Vendor
Too... I mean too funny!
To your not forgoten
Quick Reply: your not forgoten
