NEW ITEM: C3 Insulation Kit!!! $100
Former Vendor
C3 Pre-Cut Full Insulation Kit
[edited July 1, 2010: C3 Kits are 20% off with coupon... go to the post on page 9 (post #161) of this thread.]
The 1st & Original Kit!!!
CLICK HERE TO ORDER YOUR C3 KIT TODAY!!!
The MadVette C3 Pre-cut Insulation kit comes with everything you need to insulate and provide sound deadening in your Corvette, including Pre-cut pieces for your doors.
We have made the 1st and the Original Insulation Kit for the C3, and our kit is complete with pre-cut pieces for your doors, which allow road noise to be present in your front cabin. Our kit gives you everything you need to COMPLETELY insulate your C3 Corvette. We have sold hundreds of these kits for C4, C5 and C6 Vettes, and now we are proud to introduce the long awaited C3 kit!!!
Our kit is a non-fiberglass, non-asphalt based product which weighs in at 3 lbs., for those who are weight conscious, it rejects 97% of the radiant heat, and has a manufacturer's rating of 10db of sound and road noise reduction!!!
It is only 3/16" thick, so as not to interfere with proper mounting of your panels and seats, and all holes are pre-cut & clearly labeled for your convenience.
It is our #1 goal to provide you ease of install, while making a HUGE improvement in your overall enjoyment of your Corvette!!!
Each kit is hand cut to our specifications, and guaranteed to make a dramatic difference in your C3!!!
Each kit comes with the following pieces:
Say goodbye to over-heated center consoles, and noisy front cabins!! Our C3 kit is the perfect addition to your C3, and is recommended for every Corvette owner as the #1 modification for their Corvette!!!
Your Corvette will be cooler in the summer, alot less noisy, and you will be able to enjoy your Corvette so much more.
- Driver & Passenger front floorboard pieces, with holes cut for seat bolts and pedals.
- Driver & Passenger side tunnel pieces, cut around your screw holes.
- Driver & Passenger side Door Panel pieces.
- Cargo area floor pieces.
- Full Side rear wheel well pieces.
- Full back wall and corner pieces.
- Pre-cut piece for wall behind seats.
- Extra pieces for odds and ends coverage that you may need.
Alot of research and development has gone into this kit, and we are proud to say that our kit is made to our demanding specs, in house, and cut off of our own templates.
Look real nice, and at a good price. If I don't place my order later on today, I'll probably place it Monday afternoon, so that you guys can ship one out to California.
Don't you want the [reflective] foil side toward the heat source? Or is there foil on both sides?
1 Post
I just saw another thread where a guy did a great job making templets and cutting out all the pieces to fit perfectly. It looked great but dang it sure looked like at least $100 worth of PIA! If this mat is good, effective material, this sure looks like a good way to go!
Interesting, however not enough information is provided. How does it compare to other insulation options on the market? How long does it take for heat to penetrate it? How is it secured to the vehicle? Is it mildew resistant? What material(s) is it made from? Are there any installation instructions? Can the factory jute be installed over this product without any fit issues? Etc.
Banned Scam/Spammer
Former Vendor
Hi guys,
Thanks for the questions and feedback. I will post the answers to the questions, and if you have any other questions, post them up here, email me at sales@madvettemotorsports.com, or call me at the shop at 615-907-8125.
The material is reflective on both sides, and the closed cell foam in the middle is the crucial part in the noise reduction. The material is non-toxic, it is mildew and mold resistant, it withstands temps to 325 degrees, it is cut to shape, and for every bolt and screw, they are cut out as well.
It is great for blocking heat, due to it's reflective nature, and while it doesn't block out all the noise in the cabin from the outside, most C4, C5 and C6 owners have noticed a drop in noise of about 7 to 10db.
I recommend to either tape or glue it down, depending on the condition of your floorboard and panels. Tape is an additional option, which you can add to the order, or you can buy the aluminum HVAC tape from Home Depot or Lowes, as well as spray down adhesive.
I am in the process of finishing the instructions for the C3, as I have one here now that I am taking pics from as I have been installing the kit. To give you an idea on my level to which I write the detailed instructions, feel free to see the C4, C5 and C6 instructions located at www.madvettemotorsports.com/pdf.
I install the kit in about 4-5 hours time, and depending on your comfort level, I would allow a good day to do the complete teardown, and install. I charge $200 to do the install at my shop, and if you'd like to schedule an install, please call me as soon as you can. I have time open in the next few months, but I have been scheduling appts. for Nov. and Jan. already.
Best way to contact me is at the shop or through email, as I don't get to get on the forum alot during the day, so please be patient if you don't hear back from me on the CF immediately.
I just did a stupid thing with my 78'. I replaced the carpet and just used the Fat Mat stuff and didn't replace the old sound deadener. I have side pipes and it made a BIG difference in the sound level without the sound deadener. The Fat Mat stuff didn't do squat for sidepipe noise, so I'm in the market for this stuff.
Gary
Gary
Running a vert WITH hardtop on and secure, OR a coupe with t-tops on and securely....windows up, obviously you can assume every 3 db in sound reduction is about 1/2 the road noise....
issue is that with windows down and ANY convertible, it's not to matter one damn bit....
I canceled my order for a door insulation kit that was on backorder at another vendor, and ordered your kit today. The price is very reasonable considering the door kit I had ordered was $30.00 on its own. I just hope it will block out that floor board heat I will report back on my results, Thanks Jeremy
Man that kit would have been nice 2 years ago before I spent about $300 on Dynamat and added 50lbs of weight to my car....and I would have GLADLY paid you $200 to install it....I spent 3 days installing 2 layers of D-mat and sadly, heat still gets through it(although 20x better then stock)....
Glad someone is finally coming out with a product for this problem specifically for C3s.
Former Vendor
Gary
Gary
Of course, there are many materials on the market that will do thing better than the other, and some that specialize in reducing noise or reducing heat better... but no other kit on the market does both, and does both to a level that is pretty satisfying to all of our customers. That is the biggest advantage of our material and our kit- well, besides the fact that it is pre-cut for the C3 interior. Hope that helps answer some of your questions...
It takes double the power and cone area of a speaker to make a 3db gain, and for every 3db drop, it is reduced by half. Of course, there are always factors to take into account when measuring sound level... the speed you are traveling, the road needs to be the same for both tests, whether the windows are down, how good are the seals, etc. etc.
That is one thing most all of my Corvette customers have noticed the most- the reduction in the heat level of the floors. The C6 Vettes are the worst about floorboard heat, and everyone has been satisfied with the results.
Hope these help to clear up any questions. Of course, if you have any other questions, feel free to pm me, email me at sales@madvettemotorsports, or call us at the shop at 615-907-8125.
