Body Lift Straps
Body Lift Straps Problem
I was planning on removing the body from my 73 yesterday but discovered a problem with the straps I have. The opening in the hooks is not wide enough to get on the steel body support, behind the bottom trim. If i used it the way it is, all of the lifting pressure would be put on the fiberglass, not the steel. Anybody else run into this? I bought the straps from Zip. I called them, but the manager has never returned my call.
I couldnt use the strap i bought from Ecklers either? poor design. they should stop selling it it doesnt work. I used a different set of straps i got locally.
Granted I've had my body lift straps for a number of years, they worked perfectly for removing the body on my '81. They hook under the rocker channels. At first glance they appear to be just grabbing fiberglass but they are really being supported by the metal in the rocker channels. Maybe the ones you have are a different design? I thought they were all pretty standard though.
Platinum Supporting Vendor
I believe I may have talked to you earlier. Just had a chance to take them to the back. I compared them to my straps I have been using for the past 11 years and minimum of at least 40 bodies. The only difference in them is the new set has a coated metal hook where mine are plated. The straps hit the body but that is not what is lifting the body. In order for them not to touch the body, the upper hook would have to be wider than the body so the straps would be going away from it. There is another thread on here if you search it they are lifting and 65 body and they placed terry cloth towels under the straps to prevent any paint damage. I have lifted with and without doors on the car and it works both ways.
Justin
Justin
Justin
Justin
This is how the front strap fits:
The hook needs to go inside another inch and a quarter for the hook to contact the metal.
This is how the rear strap fits:
The hook needs to go inside another inch for the hook to contact the metal.
I think either the 3/4 inch opening in my hook is too small, or the length of the hook that goes between the body and frame (two inches), is too long.
What side of the car are you on in the front picture? You should lift under the hinge pillar. Your strap is no different then my 11 year old set of straps and they have removed a ton of bodies. Their has to be something else going on here. Can you take the hook by hand and set it all the way up in there or are you letting the hoist just pull it up and that is where it stays?
I was able to lift the body enough to clear the frame. I put it back on the frame, and will pull it completely tomorrow, when I have some help.
The only complaint I have with my straps is that they are way too long. I see that you had to tie a bunch of knots in yours to shorten them. We usually wrap them around a piece of pipe .
That's a great idea, I never thought of. My first lift showed I had to remove one knot from both of the front straps. Even though they had their share of the of weight applied, removing the knots was easy.
I thought it might be time to give an update on how I overcame the problem.
I took a short piece of 3/4 pipe and placed at the opening of the hook. next I put the hook and pipe into a good sized bench vise, and turned the handle with a cheater, until the hooks opened up to about an inch.
They fit perfectly.
They fit perfectly.
Maybe too late and straps are way overdesigned, but...
Maybe too late and straps are way overdesigned anyway, but putting a knot in them actually weakens the strap. Nice gradual load is one thing, but if you get a dynamic load (jerk or bounce), not good. I actually saw an industrial demonstration with a strap with no knot and strap with knot and the strap with a knot broke at a lower load than the straight strap.
I would think shorting them another way would be much better.
Hope this might help.
