79 vette Headlights
79 vette Headlights
I am experiencing an issue with my headlights. all of a sudden they wouldn't come up when the switch was turned on. i can open them manually and they will stay on while running. if i pull the vacumn switch under the dash, they will stay up after engine is turned off. i pulled 25 inches of vacumn to the system and it will hold vacumn with engine off. where should i start. no vacumn leaks and everything works fine except coming up. the engine has 18 inches of vacumn at idle.
thanks
frustrated vette owner
thanks
Received 1,469 Likes
Cruise-In II Veteran
The override under the dash bypasses the headlight switch and allows you to cycle the headlight doors a time or two with the engine off.
(I apologize for the original diagram. There are two of these available, an incorrect version and a correct one. I thought I had deleted the bad one, but --naturally-- deleted the good one.)
You're lights turn on though when you pull your switch, just not up? Sounds like either the switch isn't holding well or perhaps the relays may have an issue???
