Will 255 60s rub or not??????
Old 08-17-2009, 07:04 AM
saber
saber's Avatar
Default Will 255 60s rub or not??????
Buying some tires for my 75 in the next couple of days.
Would like to use the 255 60 15s all around.
I have standard rally wheels and want the biggest tires I can use. I have read all of the posts but no definitive answer. Will I have to run two different sizes to get the biggest tires? Any help?
Mark
Old 08-17-2009, 07:09 AM
Jeffery73
Jeffery73's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13
From what I understand, it's a bit of a crap shoot. Some cars rub and some don't. I just got new tires for mine on Saturday and got 235 60's for the front and 255 60's for the rear.
Old 08-17-2009, 07:29 AM
Steve~74
Steve~74's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
On my 74.....no rubbing....
255/50/16 Fronts
255/50/17 Rears
Old 08-17-2009, 09:32 AM
rydoc
rydoc's Avatar
245`s front, 255`s rear work for me. No rubbing issues
Rod
Old 08-17-2009, 10:43 AM
SteveG75
SteveG75's Avatar
255/60R15's on my '75. No rubbing with the stock rims but it is close.
Old 08-17-2009, 10:47 AM
Sundevil64
Sundevil64's Avatar
Default tires
My 74 does rub slightly in the front. 255's
Old 08-17-2009, 11:29 AM
tonak
tonak's Avatar
255/60 on a 79 rub, but I live with it for now
Old 08-17-2009, 11:43 AM
larryg3
Support Corvetteforum!
larryg3's Avatar
I have 255 60 r15 on my 81 with no issues at all.
these were optional on all 78-82 vettes
Old 08-17-2009, 12:21 PM
C3 Stroker
C3 Stroker's Avatar
....had them on my '69, slight rub on sharp turns in front.
Old 08-17-2009, 12:27 PM
Brooklinite
Brooklinite's Avatar
Same as my '77
Old 08-17-2009, 01:29 PM
shmoky
shmoky's Avatar
255/60/15 on all four corners with no problems on my '68.
shmoky
Old 08-17-2009, 01:51 PM
MCMLXI
MCMLXI's Avatar
Finalist 2022 C1 of the Year - Unmodified
2020 C1 of the Year Finalist - Unmodified
C1 of Year Finalist (stock) 2019
255's rubbed slightly in the front - switched to the 245's - with stock rally rims
Old 08-17-2009, 02:39 PM
RobbSalzmann
RobbSalzmann's Avatar
St. Jude Donor '12
I have 245/60's in front and
275/60 in the rear.
Fronts rub at steering lock only, rears no rubbing.
Old 08-17-2009, 11:09 PM
jn76vette
jn76vette's Avatar
St. Jude Donor '08
It varies from car to car. I run 255/60's all the way around. It's close, but there was no rubbing until a lady ran into me. Now it rubs slightly on the side that was hit. Hopefully it will no longer rub after the new fender panel is put on.
Old 08-17-2009, 11:51 PM
dmeesq
dmeesq's Avatar
235 front, 255 rear no issures
Old 08-18-2009, 01:51 AM
CraigT79
CraigT79's Avatar
Same as the 79 I had. Only in tight turns or when turning and the front dipping a little. Should have went 245 on the front.
Old 08-18-2009, 01:58 AM
MakoShark72
MakoShark72's Avatar
Rod
Same here, no problems
To Will 255 60s rub or not??????
Old 08-18-2009, 01:59 AM
LS4Wedge
3rd Gear
LS4Wedge's Avatar
Just bailed form CorvetteForums after 4 years... hope you don't hold it against me...
I run 235/60-15's on the front and 275/60-15's on the rear of my 73 454. Been using BFG TA's for 20 years because of the look. If you choose this size for the rear, you will have to go to a smaller speedo gear to keep the mph correct.
Old 08-18-2009, 09:14 PM
jfleye
jfleye's Avatar
255's on the rear 235's front-- no probem and make the car sit better to me.
Old 08-18-2009, 10:08 PM
Glass Act
Glass Act's Avatar
Location: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Running 295/50/15 rear 265/50/15 front on our 79 without issues, but my complete suspension is rebuilt.
Saber, 245/60/15 might be best on your 77
Quick Reply: Will 255 60s rub or not??????
