Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-23-2009, 12:05 AM   #1
shank0668
CF Senior Member
shank0668's Avatar
Default Decoding trim tags.................
Where is a site?
shank0668 is offline   Reply With Quote
Old 07-23-2009, 12:17 AM   #2
KapsSA
CF Senior Member
KapsSA's Avatar
Don't know a site, but here's an example I can explain...
Click the image to open in full size.
At the top, 'K24' is approximate date of production, can be off a day or two. This date is July 24. K being the 11th month of 78 production. 78 production started in Sept 77.
Trim '29C' is dark blue cloth.
'13U' and '07M' is the paint code. In this case silver upper, grey lower.
Post what you got and we'll let you know what it means...
KapsSA is offline   Reply With Quote
Old 07-23-2009, 12:45 AM   #3
shank0668
CF Senior Member
shank0668's Avatar
Trim I or 122 paint i or 131 or l other j1 or l 3
Old 07-23-2009, 01:01 AM   #4
shank0668
CF Senior Member
shank0668's Avatar
its oyster interior but the paint tag is like? 13L? Silver then L?
Old 07-23-2009, 01:22 AM   #5
KapsSA
CF Senior Member
KapsSA's Avatar
You're not being real clear, but oyster is 122. 13 paint is silver.
Does it give 2 numders for paint? May be a silver anniversary original paint.
Are you saying J1? That would be June 1(but should be J01)
Old 07-23-2009, 10:02 AM   #6
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
Trim tag is on the driver's hinge post and visible when the door is open.
Post a pic of your tag and we can decode the numbers. An alpha I is sometimes substituted for a numeric 1.
Easy Mike is offline   Reply With Quote
Old 07-23-2009, 12:31 PM   #7
shank0668
CF Senior Member
shank0668's Avatar
Hard to see since it got painted black and so is everything around it........
Old 07-23-2009, 01:03 PM   #8
shank0668
CF Senior Member
shank0668's Avatar
Well Its oyster interior paint is clearly 13L and the other date think is J13
Old 07-23-2009, 02:12 PM   #9
Easy Mike
CF Senior Member
Easy Mike's Avatar
13L is the code for silver exterior paint. The "L" stands for the lower portion of the car below the belt line. If the car was two-toned, a U code (upper color) would also be listed. Since most C3s were a single color, the U codes don't show up very often. Technically the L isn't needed on a one color car.
Your time/build code is listed in the upper right corner of the tag. J is usually May; J13 would be May 13th. Go here http://www.timeanddate.com/calendar/index.html type in the year, and it will tell you the day of the week for May 13th. Any day but Sunday could work. The plant did not run on Sundays.
Old 07-23-2009, 06:29 PM   #10
KapsSA
CF Senior Member
KapsSA's Avatar
For 78, 'J' is June.
Old 07-23-2009, 07:28 PM   #11
73 454 vette
CF Senior Member
need help with my trim tag also if you could help.
its a 73
date is C20
trim is 404
paint is 914
73 454 vette is offline   Reply With Quote
Old 07-23-2009, 07:44 PM   #12
karol
CF Senior Member
karol's Avatar
Here is a site:
http://www.corvette-world.com/corvet...ifications.php
Click on the Body Paint and Trim for that info.
As far as Dates click on the 68-82 Body Build Date and that will give you the corresponding month for the letter.
karol is offline   Reply With Quote
Old 07-23-2009, 07:51 PM   #13
73 454 vette
CF Senior Member
thats different it has my paint code listed as silver metallic but the car is red and it doesnt appear to have been totally resprayed. hmmmm very interesting. there are spots on the car like under the hood where the paint is usually very thin where you can see the black body under it but no silver paint
Old 07-23-2009, 10:39 PM   #14
shank0668
CF Senior Member
shank0668's Avatar
Yeah it should be Silver. Could have been stripped of paint.
Old 07-24-2009, 03:02 AM   #15
73 454 vette
CF Senior Member
i spent the last 4 hours going over the car and i finally found a dime size spot of silver paint. it almost looks like the paint was never sprayed on the whole car. even the undersides and the tight corners dont have any silver in them
Old 07-24-2009, 08:15 AM   #16
69Vett
CF Senior Member
69Vett's Avatar
a properly done color change, paint job, you would not find any evidence of the orginal color,
atleast not on my cars. 69VETT
69Vett is offline   Reply With Quote
Old 07-25-2009, 04:17 PM   #17
73 454 vette
CF Senior Member
its all good. im glad i get to change it back to silver. i like a red vette but i like silver better
Old 12-18-2009, 08:05 PM   #18
shank0668
CF Senior Member
shank0668's Avatar
Now I have another question, it's a 13L Paint (silver) and 122 interior (oyster) it says here http://www.web-cars.com/corvette/opt...ptionyear=1978 that this was not an option, I think I recall somewhere saying if you showed up with a check, you could order what you wanted. So is this correct?
Old 12-18-2009, 10:16 PM   #19
shank0668
CF Senior Member
shank0668's Avatar
If you do the math, there is 8 other cars with same options?
Old 12-19-2009, 09:52 AM   #20
Easy Mike
CF Senior Member
Easy Mike's Avatar
Quote:
Originally Posted by shank0668 View Post
...it's a 13L Paint (silver) and 122 interior (oyster) it says here http://www.web-cars.com/corvette/opt...ptionyear=1978 that this was not an option, I think I recall somewhere saying if you showed up with a check, you could order what you wanted. So is this correct?...
I suspect your website lists GM recommended color combinations and it's possible your car could have been oytster and silver if the combination was approved by GM and if it wasn't going to cost them anything. They already had silver paint and they already had oyster interiors, so the combination is possible.
Go here http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can obtain a copy of the original dealer invoice for your car. It will list the original colors, all the equipment and options, prices, original dealer, date shipped from St. Louis, etc.
Reload this Page Decoding trim tags.................
Tags
1967, 1968, 1982, body, c3, code, corvett, corvette, decode, decoder, location, plate, tag, tags, trim
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
