T10?? Transmission Identification
Old 07-22-2009, 09:43 PM
adamj12b
5th Gear
adamj12b's Avatar
Default T10?? Transmission Identification
I am trying to find out what transmission I have. It came out of a 1969 Corvette Convertible. There was 3 numbers on the transmission not including the patent number. That 2 numbers that are on the transmission are:
392566
P00264
And the number that was on the tail-shaft was:
70S416517
Hope somebody can help me out. I cannot find anything on google as to figure out what this is.
-Adam
Old 07-22-2009, 10:45 PM
hicswa
hicswa's Avatar
392566
P00264
70S416517
-Adam
This is the cars serial number 70S416517 but this indicates it is a 1970 car. What is the serial number on your bill of sale? do they match? Not sure about this one P00264 but I think the P is for Muncie. they didn't use a t10 in 1969 or 1970.
Old 07-22-2009, 10:59 PM
steve228
steve228's Avatar
http://www3.sympatico.ca/atkinsom/history.html
This is a link to a Muncie History page, with alist of the codes stamped on the transmission.
I hope this helps.
Old 07-23-2009, 07:15 AM
adamj12b
5th Gear
adamj12b's Avatar
Thank You both for the help. I have some new information. I went out to the garage this morning and took some pictures of the numbers.
When I looked at the pictures I realized that the number is not "P00264" but is "P0C264" I did not see that yesterday. The "C" would be a March code correct?
I also have pictures of the other numbers I will post.
Hopefully with the rest of this information I will be able to find out what gears are in this.
EDIT: There also looks to be a "1" after the "392566".
EDIT2: The code is not "P0C264", It is "P0C26A"
-Adam
Main case numbers:
ID and Serial Numbers:
Tail-Shaft Numbers:
Old 07-23-2009, 09:12 AM
hicswa
hicswa's Avatar
-Adam
Main case numbers:
Tail-Shaft Numbers:
That's better. P0C26A = 1970 march 26 and A = M20 ratio
To T10?? Transmission Identification
Quick Reply: T10?? Transmission Identification
