Courtesy light flicker...
This was a problem years ago, I parked it and had forgotten about it until I started driving it again to iron the kinks out of all the new parts. While driving the courtesy lights will flash intermittently and sometimes stay on after turning the key off. I am suspecting the door switches are grounding. Am I on the right track and how can I diagnose which is the culprit?
Thanks..
Eric
Thanks..
Eric
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Eric-
Your on the right track and I think I would consider just replacement. They are to easy to install.
You can remove the old switches and see which one is failing, but I would suspect this is your problem.
Willcox
Willcox
Thanks..
Eric
Thanks..
Eric
There is one other part to this circuit and that is the light switch. The rheostat dims the courtesy lights and turns them on and off. There could be a problem with the rheostat. It is a spiral piece of wire that may be broken and one end bouncing around making ground contact.
cc
GM Cert Corvette Tech
Pro Mechanic
The d/s pin switch was the culprit on my 68 but I replaced both just for peace of mind.
Former Vendor
cc
CC, I'm sorry Victor called me today and no connector!
Willcox
