Storage of 73 corvette on two post lift.
Does someone storage theyr vette on a two post lift. I am wondering if i will be ok with doing this. Or if it could result in any problems if storaged over long periods over time.
Dont tell me to buy a four post, as the two post already are installed in the garage :-)
I have had mine hangine for a few months on occasion with no problems. A 4 poster is better for real long term but for a few months and if space does not allow it should be fine. Mine was a space issue plus I do a ton of work on mine and others, the 2 poster is much better for that.
My 72 LT-1 has been awaiting the finish of my 70 LT-1 roadster project for 2 years on my 2 post lift, now it's time to get back to the "race car" since the "wife's car" is done. No problem with 2 post storage as long as no major Earthquake hits in California where I live
If anything it would prolong the life of the suspension because the springs would be unloaded.
The springs, shocks and frame probably don't care, but if you have the rubber control arm bushings and trailing bushings, then I am sure they don't like it much. The rubber, being in a twisted torsion for long periods probably would at least shorten it's life.
I have a 2 post and don't leave them up unless necessary.
If using poly bushings that swivel, I can't see it wouldn't matter.
Again, not true. The control arm bushings are installed at ride height and torqued down. When the suspension is unloaded they twist. You think it'll be ok for rubber to be under a torsional load for months at a time? What do you suppose will happen when they unload by putting weight back on them? .....let me help you out. They'll tear. Been there, done that, bought the T-shirt to prove it.
Sorry noonie, you beat me to it!
I have changed all to poly. I have the Performance Plus Suspension Kit. And i have new trailing arms with poly.
Am i correct when asuming that i should be ok then.
Shouldn't hurt anything, but I would put the front arms as close to the front control arms as possible to minimize any frame flex.
My arms are long enough to reach up to the PSteering cylinder mount and still balance the car well.
I also have tryed to open and close the doors with the car in the air. And no difference there.
My '69 was on stands under the frame with the suspension unloaded for 14 years. When I finally decided to put it back on the road, I just set it back down and everything was just fine. I never touched the suspension. Been driving it now for 3 years without a problem.
