Pillar Gauge Pod Group?
Hello everyone
I'm interesting to add to my vert 72 a full triple Pillar Gauge Pod (2 1/16 gauge),In the market I didn't found anyone that makes a pillar pod for our vetts.
I found this site http://www.gaugepods.com/ that can manufacture a custom pillar pod but he needs a minimum order quantity of 20 per project.
If more people interesting in this triple Pillar Gauge Pod, We can arrange a group to order it.
I don't know what years have the same pillar & if the coupe and vert are also the same.
Avner
Avner
You bet!
Count me in. I'm not sure however if 3 pods is the best choice given space constraints. Two may be a better number? I actually posted a thread a week or so ago looking to see if anyone had done this and recieved a couple great photos from helpful people. I would just assume save doing the customization myself as I expect buying a unit would have a better end result.
-Andre
-Andre
AndreG
I saw you thread an the pic' of the two gauge pillar pod that look good but there are no name or item# for it.
I can leave with two gauges, trans' pressure & tmp'.
I thought to add also A/F gauge with toggle for both sides.
Avner
Avner
Transmission pressure will tell you the oil pressure in the trans' to see if it OK like the engine oil pressure, if it drop down maybe you can save it, I Install 200R4 and I want to monitor it.
A/F - Air/Fuel ratio, it will tell you if the carb' adjust properly.
(should be 14.7:1)
Avner
(should be 14.7:1)
Avner
1 Post
St. Jude Donor '08-'09-'10-'11-'12-'13
(should be 14.7:1)
Avner
(should be 14.7:1)
Avner
The smell of the exhaust will tell you if the A/F is ok. You don't really need a gauge for that either.
Requirements for me are vacuum and fuel pressure as they together can give you a warning if you are having potential A/F issues. If I could find guages that better match the stock ones better I would consider replacing the clock with just one of the two and tucking the other away somewhere under the dash but as I can't match them well I would just assume mount another set in a place where I can see them well and having them seperated from the other stock gauges the difference in appearance would not be as noticeable. It would also be nice to be able to see the fuel pressure without having to take your eyes off the road as when it is most important is when your foot is pegged and things start to get a little hairy.
Cheers
-Andre
Hello everyone
Avner
Avner
