Steps for eliminating cabin heat for under $40
#41
#43
I wrapped my headers and exhaust pipes back to the mufflers for a significant interior heat reduction. 2" X 50' rolls of Thermo Tec material is commonly available at all the discount auto shops. I did not do anything else, as everything else was working properly. Wrapping the pipes also solved my vapor lock problem on hot summer days.
#44
I put one of these in, and it's made a huge difference - http://shop.advanceautoparts.com/web...492-_-10720525
The good thing about this valve is that it's a vacuum bypass. So when there is vacuum, it's doesn't 'block' the flow, it redirects it thru the valve to the return line, bypassing the heater core.
I have a 72, so there was no stock vacuum cutoff. By t-ing into the tan line on the control, I have vacuum at the off position, and both A/C positions. This gives me pretty much exactly what I wanted, I guess it would be nice to have vacuum on the 'vent' setting too, but I can live with that.
I like this setup because I can still use the heater/defroster when I want. And I don't need to worry about build up in the heater core.
#45
Ball Valve with lever
I wanted to put out a list of the things I have done that have eliminated the heat in my 81. (I live in Texas)
2. Installed a Lever valve in-line on the heater hose to be closed in the summer months (original was stuck open): $10 bucks (Home Depot Plumbing section) note: hot water running through your heater core because of a stuck valve is like having your heater on all the time.
3. Replaced stock 195 degree thermostat with a 180 degree one: $8 bucks (Auto Zone)
Check page 2 for updated list 4-17-09
I went to the 180 degree thermostat and much prefer seeing the gauge at that temp for many reasons.
Thanks,
Lance Pearson
#46
where exactly did you 't' into?
what is the photo showing exactly?
#47
Since 72's didn't have a vacuum controled hot water cutoff from the factory, I needed to have a vacuum line to control the heater valve. In the 72 service manual, there is a chart that describes each of the vacuum hoses connected to the AC/Heater controls in the shifter console. The chart showed that the Tan vacuum hose would have vacuum when the controls were in 'off', 'AC normal', or 'AC max' settings. I cut this line under the dash, and put in a tee to run a new vacuum line to the heater valve.
The picture is to show where I placed the valve - I wanted it to be out of sight as much as possible. I've circle the valve in this picture. It's kind of hard to tell, but it's tucked down as far as possible without being lower than the frame.
#48
ok, done a bit more hunting around and have found these locally
(ford rangers are not a common car here)
http://www.dayco.com.au/products.asp...322&P=16028371
does it need to be a 4 port valve? i'm guessing thats a bypass valve
will a simple on/off in 1 hose to the heater work as good?
i have a piece of 5/8" steel blocking mine atm where the po installed a tap before
does the vacuum turn on/open the valve or off/close it?
thanks
thanks
#49
Good list.
But you also need to check the flapper door on the passengers side behind the kick panel. It has a seam that tends rot out over time. You need to sometimes reseal it. It is a pain in the butt, however; it can stop alot of serious heat from coming into the cabin. Also engine smells.
#50
Brass Shut Off
I insatlled the brass shut off valve in my 81 , cuts down on the heat but I really think it looks horrible and out of place....being as my car only come out in the nice weather with no need for heat ,I was thinking of the plugs at the water pump/block and eliminating the hoses altogether ,,, anyone try this ? thoughts?
Thanks ,
Neal
Thanks ,
Neal
#51
photos?
Thanks ,
Neal
Thanks ,
Neal
thanks.
Lance
#53
Thanks ,
Neal
Thanks ,
Neal
#54
thanks
thanks
Also, there has been discussion on wether or not when using cutoff valves, both hoses should be blocked off. The idea is that even if the coolant is not flowing, it will still conduct the heat into the core - and therefore a cutoff valve should be also put on the return hose to act as a sort of heatshield. If you use the 4 port bypass you don't have to worry about that.
The bypass that I use, the one designed for the Ford trucks, will bypass when the vacuum is applied. Therefore, when supplied via the Tan hose I mentioned, vacuum is applied with the system in 'Off' or either A/C setting, and the heater core is bypassed. All other settings and the bypass is not active, and the hot coolant will flow thru the heater core.
#55
I believe the 4 port (bypass) will work better. For one, since it's a bypass, and it allows the fluid to continue flowing along the shortened route, it will be under less pressure, and therefore less likely to leak. It's not stopping fluid under pressure, it's simple redirecting it.
#57
I put the heater core input bypass valve in and nothing else. It made a huge difference but in the summer on long drives with no outside cool air venting down at your feet the heat of the engine still heats the footwells up when it's 90+ out. I believe you really have to insulate under the carpet as well which hasn't been done in my car's case to get it cool. I wish there were a way to direct outside air while driving into the bullet vents but in my car's case it's all tied to the A/C which I've never started. With the t tops out all the time I probably never will.
Lance
Lance
#58
Can you use transmission tunnel foam on 82's? Don't think they came with the foam from the factory.
Also, consider buying a heat blanket from Jegs or Summit and put on outside of heater/air conditioner box to keep radiant heat from headers heating up box.
Why not just seal up the fresh air vents? Hardly ever use them.
#59
When the valve has vacuum, an arm is actuated, and the flow is redirected internally. The flow will be in a U shape, in one side, and redirected back on the other side. When there is no vacuum, flow is not redirected, and it will flow straight thru the ports on both sides.
https://www.napaonline.com/Catalog/C...+50028+2028014
#60
This is the part I was talking about. There are 4 ports, but in the picture at Napa, one of the ports is being blocked by the vacuum diaphragm. The ports on one side will be for the heater core input line, and the other side the return line.
