Cost me $48
Cost me $48
Dropped my son off at Karate, Went back out and the vette wouldn't start. Not even a click. It started 25 minutes later just as the tow truck showed up. I think the starter was hot even with the header blanket around it. The vette hasn't done this since I wrapped the starter, but for some reason decided to tonight. The $48 was because the tow truck showed up, it would have been $65 for the tow.
sounds like a bad connection,usualy a hot starter will turn the engine over slowly.
My 79 did this years ago. One time on my way to work it did this at the gas pump. I had to call in to work and tell them my car would not start. I caught a ration from the guys when I finally got to work. I replaced the starter solenoid and never had the problem again.
Like blue427 said, heat soak will usually manifest as a slow/weak crank. It's not so much an on/off thing like you describe. You have a loose connection or a bad solenoid.
A buddy had same problem. Bad Battery - internal (floating) short.
doesnt sound like a heat issue . mine used to do the slow cranking due to heat deal it sounded like i was turning over a mach truck! the solinoid will do what you explained. die and come back to life and finally will just quit.............until you wack it with a hammer and it lasts for another week!
1 Post
Jumpering the solenoid on your starter and putting a Ford type solenoid where easily accessed and away from heat is a great fix for this common issue. The ford solenoids are only like $15 bucks and no longer have to get under the car should the solenoid fail. Mine has been in now for about 15 years.
our 79 has done that several times, it was the neutral safety switch, you could move the shifter into neutral and it would start, replaced the switch, problem gone. just fyi
Heat soak will do this to a starter. Probably just the solenoid. When mine did it there was not a single click or anything when turning the key. Let it cool off and it fires right up. Replacing the whole unit fixed it.
I think your problem is with the battery conections and most probably the ground cable. I have put a few post on the forum about this subject. Pay attention to the short cable in the front that goes from the frame to the starter support bracket and into the block. If the star washers are missing replace them as these are absolutely needed.
Good Luck
Good Luck
Doubtful
Yeah, but when that happens the battery goes flat as pancake in a blink. He said it cranked up fine after a bit which would point to an intermittent connection.
BTW. I replaced both cables, had the battery tested--twice, checked all fuses and connections I could find, and even looked into the neutral safety switch. If it needs extra juice to start hot, starter. Good Luck
Frank
Frank
